Home > Puma (Tdci) > Narrowing down the problem-Overheating
Page 2 of 6 <123456>
munch90
still all info comes from temp sender ,obd or dash
anyone changed temp sender on a defender tdci , because on a tdci transit rwd it's gearbox out as its up in back of head next to bulkhead , only thing on a transit it's 15 mins to get gearbox out
Post #326771 28th Apr 2014 7:44pm
landy andy
I asked about air con for two reasons.
1. I think when the ECU senses extreme heat it can operate the fan. Is it doing this
2. Can you wire/run aircon fan during your test to see if a bit more airflow through rad stops problem occurring.
Andy
Post #326772 28th Apr 2014 7:45pm
munch90
don't think aircon fan is linked to engine ecu , think to aircon fan is controlled by pressure switches on the aircon ,
but could be disconnected from aircon then wired to run and see if it makes a change to temp ,
really you need to check temperature by separate way to find if indeed it is getting hot
Post #326776 28th Apr 2014 7:52pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Radiator full of mud ? I had to remove the radiator from my old 19j after an off road foray to clear the mud out of the fins just could not do it properly in situ. 2005 Td5 90 XS
Steve
Post #326778 28th Apr 2014 7:53pm
Cheshire110
Munch - i think i can see the sensor, on the back passengers' side of the block. Looks accessible enough
Landy andy - Actually my aircon fan has been grinding and squealing recently, i assume due to lack of use. Seems to make cold air ok though, just don't turn it on unless away from nearby ears! I can try that i suppose... Cheers, David
Post #326779 28th Apr 2014 7:55pm
Cheshire110
It definitely is getting hot, can hear the coolant boiling... Cheers, David
Post #326780 28th Apr 2014 7:56pm
Cheshire110
did give it a clean with the pressure washer, seemed ok but gave it a good clean anyway. Cheers, David
Post #326782 28th Apr 2014 7:58pm
Lou Sparts
Don't know if Puma a/c is the same as td5 but a/c fan on Td5 cut in at 28 degrees ambient. 2005 Td5 90 XS
Steve
Post #326785 28th Apr 2014 8:00pm
Cheshire110
Hmm so I have many things to investigate and very little ways to do it haha! Oh aren't defenders fun! Cheers, David
Post #326788 28th Apr 2014 8:02pm
munch90
ok this is a long shot , but is aircon fan stoping the air getting to the rad if the fan is dodgy
we had a race car that boiled as soon as the fan came on and found fan was stopping the air getting to rad during race , we had to fit a different style fan to solve it
I take it that with aircon turned off it still does it ( get hot I mean )
Post #326789 28th Apr 2014 8:05pm
Cheshire110
yes it does it with air con off, I've not had the air con on to try actually.
I think first step may be to go see chris (I'm sure ill find something I want to buy!) and try and get the car de-mapped and give it a quick drive to just rule that out in my head. Ill never be able to shake that nagging doubt otherwise..
Then i'll go after thermostat/fan/cooling system after that's been ruled out. Cheers, David
Post #326792 28th Apr 2014 8:07pm
Lorryman100
If you can hear the coolant boiling then it is either viscous fan, thermostat or water pump. Personally I would replace the thermostat and then if it still overheated the water pump. JMTW. Thumbs Up
Part of the EMS overheating strategy is to switch on the ac fan (where fitted) to assist the cooling, so if the ac fan is running but the ac is switched off that is a good visual indication that the EMS is enacting the overheating strategy.
Post #326793 28th Apr 2014 8:08pm
landy andy
I know on a td5 you can operate the air con fan with a Nanocom. So thought it's ECU controlled.
Post #326794 28th Apr 2014 8:09pm
Cheshire110
ok thanks for the advice guys, AC fan can't make a huge difference since most cars don't have it, although maybe the AC rad being located where it is has the opposite effect.
I'll start with a visit to chris i think, always an interesting place to stop by anyway! Cheers, David
Post #326798 28th Apr 2014 8:11pm
Happyoldgit
Just a bit of advice but I wouldn't use a pressure washer on full whack up against a radiator too much as doing so can easily bend the fins and create more problems, a decent garden hose at tap pressure is much safer Thumbs Up
FWIW I'd still want to revert to standard tune PDQ and then run through potential faults. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #326821 28th Apr 2014 9:16pm
