Home > Technical > What's this leaking
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
What's this leaking
Spent yesterday taking the box out to change the clutch only to find I may be prudent to fit a recon box. But found the starter covered in oil. It appears it is coming from just above close to the manifold but I can't identify what and where. Can anyone shed any light especially what part is pictured
The bowl like item taken from below with the box out
Post #326345 27th Apr 2014 8:14am
Is it oil or diesel? Your picture shows the fuel pressure regulator, which is well known for leaking. Darren
Post #326350 27th Apr 2014 8:34am
Sphere
It's oil. But coming from that area
Post #326353 27th Apr 2014 8:36am
JWL
That'll be your fuel pressure regulator, you can get service kits with the "bowl"(pressure valve) to repair for £40 or less off t'internet. It is quite a simple job to do especially when you can see it. Also.take a look to see if there isn't a leak from the back of the rocker cover, there is a section on the very back with a semi-circle part that is prone to letting oil out, either a new seal or use some gasket seal like Blue Hylomar to sort that one out.
Post #326357 27th Apr 2014 8:40am
In that case, it's possibly the half moon shaped gasket at the back of the rocker cover. Darren
Post #326358 27th Apr 2014 8:41am
