![]() | Home > Puma (Tdci) > Torque settings |
jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149 ![]() ![]() ![]() |
Hi All,
I wonder if anyone out there has a torque setting for the filler plug on the gearbox and transfer (NOT the drain plug as the manual states the torque for this). Also any suggestions for the axle drain/filler plug torque (if any) or is it 'chamfered'. Welcome any suggestions. On another matter, The 'original' radio has a clock facility which sometimes the clock tells the time and sometimes the screen says 'No Clock' - There is nothing in the manual about this? Any knowledge on this? Joe 'El Pepe Flamenco' JLS 'El Pepe Flamenco' |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
One thing to check for - both my front and rear diff filler plug threads were nackered from the factory.
Have a close look - I had to file mine with a thread file to get a decent fit. |
Thanks folks for your prompt reply.
Very much appreciated. Joe 'El Pepe Flamenco' JLS 'El Pepe Flamenco' |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
![]() ![]() Whats wrong with its done up, tight but not too tight ![]() ![]() |
Torque Settings General Rules:
Upto 8mm - Quarter of a white knuckle. 9mm - 18mm - Half a white knuckle. 19mm - 30mm - Full white knuckle. 31mm - 40mm - Slight 'click' in wrist is heard. 41m - 57mm - Veins on neck to stand out like head is going to explode. 58mm upwards - You should jump up and down on the ratchet handle at least 6 times, if carried out by hand bloodcells in eyes must rupture and you need to go lie down for at least 20 minutes to recover composure. ![]() ![]() ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
That works for me
On the last two settings don't be surprised if you have to do a 'trolley check' for conkers even worse if you've had a night on the cider before.
