Home > Maintenance & Modifications > Rost off
Waldo
Rost off
Has anyone used wurth "rost off plus"
Looking to give my new x-member a nice coat of paint for permanent but as it's been about a month since it was installed there is a little bit of surface rust.
So I'm going to wire brush and then treat it and was thinking this might be the product to use.
http://www.wurth.co.uk/technical-chemicals...plus-300ml
Also what would you all use for a primer.
For the top coat I am thinking Hammerite, sprayed on.
Primer preferably would be spray on as well Defender 90 XS TD5 (03 Reg)
Post #325362 22nd Apr 2014 6:16pm
Killer90
Site Sponsor
if its only surface rust try and get hold of a orbital sander or DA rub the xmember down to bare metal and then etch prime Thumbs Up then a nice coat of paint over the top. Hammerite doesnt give the nicest of finish but it does protect the xmember very well Thumbs Up got a 110 in at the minute which looks like its been done with hammerite and its very solid and is showing no signs of rust Mr. Green CSK Automotive
www.cskautomotive.co.uk
Post #325373 22nd Apr 2014 6:54pm
landy andy
Rust off is a great product, but it not what you need. ( I was Wurth rep for 5/6 years) you need a rust convertor or to remove the rust then treat as bare metal.
Andy
Post #325425 22nd Apr 2014 8:14pm
munch90
agree with above rost off is like wd40 , no good to paint over
Post #325440 22nd Apr 2014 8:32pm
Waldo
So rust converter for the bits i can't access with the wire brush attachment on the grinder.
Then etc prime.
Then Hammerite?
Any recommendations for the converter?
Will Defender 90 XS TD5 (03 Reg)
Post #325484 22nd Apr 2014 9:55pm
jimbob7
Rustoleum is another quality paint,I used it on mi chassis and rear x member last year, use a gloss roller rather than a brush for a better finish. Pov.spec,ftw. 2006, 110,TD5.
Post #325505 22nd Apr 2014 10:41pm
K9F
Fertan one of the best used in the marine industry. Do a search on here or Google it. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #325524 23rd Apr 2014 3:00am
Waldo
I do like the look of the fertan stuff.
It's on the list
What are suggestions as to how to remove what paint there is from the inaccessible areas before applying this stuff.
There is obviously only so much you can access with a grinder?
I was thinking some form of paint remover.
Then the whole thing can get coats of fertan, etch primer and then paint Defender 90 XS TD5 (03 Reg)
Post #325562 23rd Apr 2014 10:23am
jimbob7
Wirebrush onna drill,but dont buy the cheap ones,I was pulling wire "splinters" outa mi arm fer days afterwards,a real thick washing up liquid solution and a 3M Scotchbrite (industrial type green/red scouring pad) for heavy duty cleaning, de-greasing,keying the paint and light rust removal.You can paint straight over the existing sound paint just get rid of as much of the loose rust as you can Pov.spec,ftw. 2006, 110,TD5.
Post #325573 23rd Apr 2014 11:29am
Waldo
I think that's all I need then.
Wirebrush on drill + Scotchbrite pad with washing up liquid to get all I can off.
Then spray on the fertan and wait 48 hours for it to do it's stuff
Rinse it all off with low pressure hose.
Then spray on an etch primer.
And lastly put on a top coat.
Thanks chaps. I'll try and get come photos.
May not be for a week or so as I think I'm going to pop the floor and drop the tank to do both sides.
Post #325576 23rd Apr 2014 11:47am
landy andy
Get some treatment on the inside of all the welds if you can.
Andy
Post #325587 23rd Apr 2014 1:21pm
Waldo
I assume there shouldn't be a problem with applying Hammerite Direct to rust aerosol paints to an etch primer? Defender 90 XS TD5 (03 Reg)
Post #326058 25th Apr 2014 8:45pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Hi Waldo, When I did my rear crossmember I sprayed it with etch primer and the top coated with smoothrite gloss black got a great finish and still looks good a year later.
Received the side steps at work this afternoon Thumbs Up Not unpacked them yet but I,m sure they,re all the judging by the weight. 2005 Td5 90 XS
Steve
Post #326063 25th Apr 2014 9:01pm
Waldo
Excellent, glad they arrived okay.
In that case i'll just slam hammerite over the etch primer.
Need to do a long trip so I can train some fuel out to drop the tank.
Don't fancy dropping it out by hand when i've only done 60miles from full. Defender 90 XS TD5 (03 Reg)
Post #326068 25th Apr 2014 9:14pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
One of the best treatments I've found for rusty metal is POR15, it does all the stuff that Hammerite is claimed to do and more, it really does stick like $hit to a blanket.
Post #326085 25th Apr 2014 9:42pm
