![]() | Home > In Car Electronics > Is there a speed pulse available? |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
If I'm not remember wrong (the pin number I meam) pin14 tacho conn.
http://1drv.ms/1mGwcmT here all infos that you meed Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
| TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752
I went back, direct to the gearbox sensor for the speed pulse for nav and cruise control California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Main Brian James Trailer Dealer for South West UK |
| chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559
for anyone looking for a speed plus wire - on my 60 plate i used the "black and red" wire (pin13) in the instrument cluster and earthed the hand brake wire.
Good choice Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
| Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630
TJ101... Can you let us know what wire you piggy backed off..
Cheers Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
