![]() | Home > For Sale & Wanted > [For Sale] Defender Armoured Glass |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
Random For Sale ad of the day!
I have four side window sections which were removed from my Armoured 110 when I converted it. There are the real mccoy - the vehicle was designed to stop 7.62 Ball rounds, and the sister vehicle to mine was tested and certified by Qinetiq on their range. These will fit into the apertures in standard Defender doors without modification - they were fitted with Sikaflex which is the approved method. In case you are planning to do something else with them, the square pieces are 428mm x 628mm x 40mm thick. The front sections are 444mm top to bottom - widest width is 722mm, narrowest width is 534mm, thickness is 40mm. One of the front windows has a 2 inch scratch in the outer side - which may polish out...? Price is £50 for all four - collection only for oblivious reasons from RG27.... ![]() ![]() ![]() 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Just seen your build thread.
Interested in the door cards.....are you still using them?? |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Although I have no use for these whatsoever, I still really want them
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2267 ![]() ![]() |
How did that window get e scratch , did you run over a land mine ?
Must have dropped a sledge hammer on it 2002 90 Td5 Station Wagon
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 ![]() ![]() |
I really want these just so I can claim I have an armored LR Defender 90 XS TD5 (03 Reg)
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
Bit of a bump - still available... My blog - www.anacreinhampshire.blogspot.co.uk
