![]() | Home > Technical > td5 fuel pipe |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
I think that's the one that split on me on the way to France last year. You will need the full pipe and (last year) it was only about £15 from main dealers so probably best to order from them as it should be right first time.
| simon77 Member Since: 20 Apr 2014 Location: berkshire Posts: 8
Ok, thanks for the info.
| ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221
If you want to "try before you buy" I have a full set of Disco ones sitting around doing nothing. It wasn't me!
Thank you very much for your offer if i get stuck I'll give you a shout!
Does anyone know the part no. This pipe ?? |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
Need to know if you have a 90, 110 or 130 to start with.
Then what engine you have (10P, 15/16P) as the ends are moulded differently to suit the different fuel cooler. |
Hi, it's a 1999 110 hard top sorry but not sure of engine number will check when I get home it is the original engine though.
1999 should be 10P
Thanks jim, so now we know that does anyone know the part no. ??
Thanks Simon |
Should be WJP500090 (was previously WJP107910)
Cheers thanks for the help !
| All times are GMT |
