Home > Puma (Tdci) > intercooler standard or bigger ?
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
hi guys im still on a stock intercooler has any one changed theres and which make
cheers steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #32549 19th May 2010 6:01pm
K9F
I am considering travelling down the same path, other considerations that may have to be taken into account is how would it affect your remap (if you've got one)? A quick search reveals the following thread on the subject already...
Started by you? Did you not get a satisfactory answer first time round?
http://www.defender2.net/forum/topic3141.h...ntercooler
Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32551 19th May 2010 6:14pm
big steve
no not really i know robofarmer has a allisprt one i was wondering if any body else has a different suppliers fitted and whether its benifited them
currently i have
bas remap
itg filter (but put standard one back in now )
full stainless exhaust only a resinator in the centre pipe
and the new egr blank(14mm atm )
but asd i said before i ahve a big slab of metal in the front (winch and bumper)
im pretty sure a allisport one will fit but the price he gave me today nearly mad me cry !!
and that was without pipes
so im interested about any other manufactures that people have fitted ?
Post #32566 19th May 2010 8:39pm
K9F
You will need to speak to Pete as with a BAS remap you need to know if a larger intercooler will actually benefit you in any way. According to him from a historical post (see below) with an Autologic remap there are no gains to be had. You may be wasting your money. I need to do more research to see if I with an Autologic remap the information is correct. I would not be best chuffed paying in the region of £400 for an intercooler with no benefits to be had.
bell-auto-services wrote:
The bigger intercooler is not needed on the autologic tune, the inlet temps and flow rates of the standard intercooler is fine for this application.
It wont add any extra power fron just adding the intercooler.
You may want to consider a Decat front exhaust, this will help the turbo spin up faster and free up the whole system.
Regards Pete
Post #32569 19th May 2010 8:53pm
big steve
appretiate that k9 but as i said i do have a twin motor 8374 on th front tucked behind 12mm of steer and you can only see about 1/3 of the intercooler
therefore letting hardly any air threw it pete said the same to me basically but he also did agree about the winch that blocks so much of it ?
and surely a bigger intercooler just makes things run even colder
and colder is better ?
Post #32570 19th May 2010 9:08pm
K9F
I know what you're saying Big Steve about larger area more cooling, and I am unsure of intercooler physical sizes.
I think the principle of a replacement intercooler is not the fact that it is necessarily physically larger in cross-sectional area in the airflow (3 or 4 times usually) but the fact that the matrix itself has a 3 or 4 times more volume giving a much more efficient cooling. To achieve this there is more matrix in the same or similar size of intercooler the matrix can also be 'sandwiched' in certain types to keep the size similar to the original.
Basically if you mask a certain area of your intercooler off, the same cross sectional area will still be masked on the replacement intercooler.
Hope this makes sense. I know what I myself was trying to get across. Dog Thumbs Up Dog
Sure someone with the true facts will pop along to enlighten us! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32576 19th May 2010 9:30pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
This is RoboFarmers personal PA, (currently having a beer together)
He has a BAS Remap, 14mm blanking plate and just installed an Alisport Intercooler. There are benefits from the blanking plate alone from which you'll see on the EGR thread. If you go an add an intercooler aswell this will compliment the whole setup even further. I have noticed massive increase in MPG and performance after installing the intercooler on Sunday. Figures to be quoted.
I can't reccommend fitting one enough, colder air can only be good for the engine and compliment the setup as a whole.
Here are some pics of RoboFarmers Truck and installation:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  1964 Series IIA SWB Truck Cab - gone
1981 Series III SWB Hardtop - gone
1982 Series III SWB Hardtop - gone
1997 300Tdi Defender 90 Hardtop - gone
1983 Series III SWB Station Wagon - gone
1979 Series III SWB Station Wagon - gone
2007 90 CSW - gone
2010 USW XS - gone
2010 110 USW - gone
1959 Series II Truck Cab
1984 Series III CSW
2004 TD5 90 CSW
Post #32583 19th May 2010 10:10pm
K9F
Thanks Mr Woo,
Maybe i'll move the intercooler purchase off of the rear burner and give it more consideration again! Had already nearly spent the money on a decat pipe or whole exhaust system. So many 'needs' so little dosh! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32586 19th May 2010 10:15pm
big steve
a de cat pipe is a good buy you will noice a difference straight away
i did when it was still on standard tune
i just want to get the intercooler and pipes at a descent price Sad 2015 2.2 tdci hardtop xs
Post #32592 19th May 2010 10:44pm
K9F
Try 'Alive Tuning' one of the site's sponsors. His site member price seems quite competetive on the intercooler front. They do exhausts as well. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32593 19th May 2010 10:49pm
big steve
i ment silicone pipes lol iv already got the exhaust
cheers k9 2015 2.2 tdci hardtop xs
Post #32596 19th May 2010 10:58pm
K9F
Embarassed My fault, your mistake! Laughing Getting late! Embarassed
I thought it may have been a flute you were after! Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32598 19th May 2010 11:01pm
Naks
If you fit an aftermarket/bigger intercooler, does this not affect the warranty? Confused
Post #38244 16th Aug 2010 12:35pm
big steve
if look at my pic of my truck does it look like they are guna touch it for warranty
i think mine could me one of the most modified pumas around
lol
yer it possibly could 2015 2.2 tdci hardtop xs
Post #38280 16th Aug 2010 7:34pm
Hey Steve so apart from the lift cage and big wheels what else you done Wink I think you will agree that there are many ways to mod a defender and that's one of the many things that make them so Mr. Green
Post #38281 16th Aug 2010 7:51pm
