Home > Td5 > Wiper fault
kevinf
Wiper fault
Hi folks
I know this topic as been posted before but does anybody know if the wiper motor park switch is available separately and if so the part no, or do I have to buy a wiper motor, my vehicle is a 2002 td5 on which the wipers won't park and I have confirmed that the fault is at the wiper motor
Cheers Kevin
Post #325504 22nd Apr 2014 10:40pm
jimbob7
£25 (ish) from Landrover dealer,as usual genuine parts are best. Pov.spec,ftw. 2006, 110,TD5.
Post #325507 22nd Apr 2014 10:44pm
mk1collector
You can buy them separately (not sure on part number though) only buy genuine as cheaper ones don't last.
Post #325508 22nd Apr 2014 10:44pm
grumpy old git
Examples of prices (no affiliation) 520160 - Switch Park Wiper Motor
Definitely avoid the blue boxes, I replaced the one on our Tdi and had to repair it before I fitted it!
Post #325529 23rd Apr 2014 7:19am
kevinf
Thanks for the replies
I had got to that white block on the wiper motor but after much tugging and pulling couldn't get it to move and didn't want to keep trying and damage a otherwise functional wiper motor now I can attack it with more confidence
Cheers kevin
Post #325531 23rd Apr 2014 7:40am
grumpy old git
They take a bit of wiggling to get off, the spring clip locates in a slot and all will become clear once you've got it off Thumbs Up
Post #325535 23rd Apr 2014 7:48am
The photo above actually is really good for showing how the switch is retained.
The two small pegs you can just make out in the photo locate the switch, and the spring clip holds the switch in place (and the pegs in their holes). To remove, pull the switch very slightly away from the motor to free the pegs, then slide it sideways to release the clip.
The first time I changed one it took me longer to get the damn thing off the motor than it did to strip the dash apart to access the motor!
Post #325545 23rd Apr 2014 9:16am
kevinf
part ordered from local main dealer, as mentioned earlier £26 ish plus vat.
any body want a genuine lucas wiper stalk switch as supplied by paddocks only plug into wiring loom once only to discover i'd got it wrong Embarassed
cheers kevin
Post #325558 23rd Apr 2014 10:11am
kevinf
park switch arrived and fitted all faults cured
thanks for all the help! Very Happy
cheers kevin
Post #325807 24th Apr 2014 12:29pm
