![]() | Home > In Car Electronics > Bolt on Bits RDX flasher Relay does it work as claimed |
| foxkilla Member Since: 01 May 2009 Location: J23 M1 Posts: 156
Yes it works as advertised DEFENDER XS UTILTY 110 AUTO
ONLY ACCURATE GUNS ARE INTERESTING |
| keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2274
Mobile centre on here will also do the plug in relay for led indicators .
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
it works as long as you don't have led lights on trailer
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939
I'm confident enough to believe what I've heard.
I went for the RDX LED lights, and I am pleased with those too. I have the indicators front and rear, just need the relay now too, but like you say at nearly £30 they aren't cheap. But you get what you pay for on the flip side. |
Well it will still work but just with resistors on the trailer. If it's ordinary incandescent lights on the trailer then no problems at all. |
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5135
I have a Bateson Trailer and a Elddis Caravan both have ordinary incandescent bulbs fitted.
If the RDX flasher relay works then I will probably go for one, especially as I have heard that some LED relays can blow when a trailer is hooked up. |
| Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226
Mine definitely works with no trailer and it definitely works with a trailer with filament bulbs.
The RDX relay can take up to 120w.
Two trailer indicators that are incandescent will be about 42w the pair (21w each) That doesn't include the LR's own indicators too of course but that isn't much wattage. |
I brought a flasher unit years ago that can take all led or all normal bulbs or mixed , has max load of 160w ,it's three pin so won't work the trailer light on dash at all so I fitted a buzzer for indicators which I prefer to be honest
I brought a Rdx adjustable flasher unit , but having led lights on my trailers it wouldnt work the dash light , (yes you can fit resisters but I think that defeats the object of having led lights in the first place ) but I removed it before it left my workshop as I found the flash rate looked a bit slow ,it was still within mot regulation speed , but I thought the flash rate looked a bit old fashioned like the old bi-metal flasher units , but that's me being fussy |
When I fitted my led indicators I didn't know about the simple plug in relay , so wired and soldered resistors to each corner only to find that the lamps were still flashing fast and the only way to sort it out was to also re-wire back in the original bulbs and holders . Aarrrrgh
Only to be told after all that work " there's a relay to save you doing all that " |
Just snip it off and put female Econoseal connectors on the LR side and male Econoseals on the lights side.
True, but if like me I don't tow that often so it's worthwhile. I'm not a fan of resistors either but for that small compromise you retain full OE functionality for the LR. That IMO is worth it, much better than having the trailer light on all the time. Yes it flashes the once and off but IMO if an MOT spotted it for a start flashing constantly I think he'd think ah hah there seems something funny here.. After all it's self explanatory by being a trailer symbol and it's obvious that it shouldn't be on when not actually towing. I doubt there is any issues ensued by that but it could well be viewed with suspicion. Just a shame about the trailer functionality or it would be a near perfect device. |
mines not on ever , not first flash or when trailer on , that's why I fitted a buzzer which I have had tell me the trailer indicator had gone out and to be honest I don't think I would have noticed the light on the dash not flashing when trailer light out on a busy junction when you shouldn't really be looking at your dash
| SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527
Wipac on works fine on my 130
