Home > Maintenance & Modifications > Foxwing mounted to hannibal rack
a13x
Guys I believe I have all the parts needed to fit the foxwing to my hannibal rack. Have the tracklander fitting kit which can be seen loosely bolted to the rack below.
My concern is the width of the mountings, the rack has a table and so with the tracklander fitting kit I can only get a distance of 800mm between mountings. This be enough? Any alternative way of mounting? Don't really want to drill the rack.
Post #324904 20th Apr 2014 5:10pm
a13x
Anyone with other mounting options for a foxwing to hannibal rack?
Post #325294 22nd Apr 2014 2:03pm
leeds
Have a look at section 6 on the Foxwing fitting instructions HERE
Minimum distance between two fixing points 900mm. Maximum distance for a support from either end is 900mm.
Personally I prefer 3 or 4 supports but that is a case of belts and braces.
Brendan
Post #325431 22nd Apr 2014 8:22pm
a13x
Thanks Brendan, I thought as much. Looks like the track lander kit is not suitable for my needs.
Custom brackets may have to be an option if nothing else on the market.
Post #325434 22nd Apr 2014 8:27pm
