Home > Technical > Advice please - tbox ratios
Alex1976
Hi All,
Wondered if I could get some advice from you please........
I have a 300tdi tuned and with a BAS VGT turbo. It has a ZF auto box and a 1.2 Tbox. I usually just drive around on A roads and so far it has been fine, but at the weekend I went down to the south coast and on the A34/M3 it was a bit of a 'big dipper' section of road and I was really struggling to maintain any decent speed (60- 70) on the uphills. It is fine on flat roads and cruises along lovely, but I didn't like how it lost all its speed on the hills (even fairly minor uphills).
Should I change to a 1.4 ratio tbox? Looking at the Ashcroft site it says I should be aiming for 2700revs at 70 in top gear. Using the ratio calc I get 2346 revs at 70 now and if I swap to a 1.4 I will get 2707 - so it would seem to indicate that's what I should do.
Any thoughts before I spend about Ł600 on a new tbox from Ashcrofts.
Thanks,
Post #325257 22nd Apr 2014 10:25am
Cheshire110
no experience with tdi autos sorry, but 2700 ish rpm sounds more than enough to me for top gear @ 70.
Obviously a manual 2.4 tdci has more power than an auto tdi but my 110 (2.4) copes fine and 70 comes up around 2350rpm, and it'll accelerate up some fairly steep hills in top gear up to the limited top speed of 82.
Only thing is, if you drive at 70/75 on motorways etc, then 2700-3000rpm may get a bit noisy and uneconomical? Don't know a lot as I said but could an overdrive and lower gearing together be a good option? Cheers, David
Post #325268 22nd Apr 2014 11:03am
Ashcrofts advice is spot on. Your truck is over-geared and changing to the 1.4 box will solve this.
Comparing it to a Puma Defender is meaningless, I'm afraid, as the gear ratios and engine characteristics are completely different. Darren
Post #325277 22nd Apr 2014 11:41am
grafty99
Surely a tdi engine, properly setup with a VGT turbo would have the power to pull that kind of gearing? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #325333 22nd Apr 2014 5:04pm
Alex1976
I wasn't sure at first if it was lack of power/engine issues that was the problem, but it doesn't seem to be as there is plenty of power and go generally, it is just the problem of maintaining speed on motorways when there is an incline, it seems to struggle.
So I am thinking the 1.4 Tbox is what is needed.
Thanks for the replies.
Post #325337 22nd Apr 2014 5:09pm
Romadog
Now I was thinking of going the opposite with my V8 !
Rechecking calculator.........
Post #325365 22nd Apr 2014 6:22pm
grafty99
Aren't there different torque converter sizes as well? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #325481 22nd Apr 2014 9:48pm
barbel jim
I'm looking to go the other way, could be interested in your old 1.2 box Wink
Post #325482 22nd Apr 2014 9:52pm
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
+ tyres that you run make huge difference - road or ATs very little drag, MTs quiet a bit more, simex or similar extreme drag.
Post #325584 23rd Apr 2014 12:48pm
Alex1976
I am running 265/75R16 BFG AT's so shouldn't have too much of an adverse effect.
Ashcrofts do a larger torque converter option but they advise against fitting this unless you have 'a very tuned 300Tdi' or it has negative effects. I don't consider my 300tdi 'very tuned' so I am leaving the TC alone.
I am swapping my 1.2 box in for a 1.4 from Ashcrofts so it's not up for grabs sorry.
Alex
Post #325597 23rd Apr 2014 1:51pm
shaggydog
Remember the max revs of a Tdi is 3850 so although 2700 sounds quite low, its actually top of the middle range.
Post #325604 23rd Apr 2014 2:25pm
g-mack
couldnt imagine doing 70 for long in mine! Rolling with laughter im also thinking about 1:2 box to ease the revs !! My 109 thread
my youtube channel
Post #325634 23rd Apr 2014 5:22pm
shaggydog
I had to push to 70 this evening to get around a truck.
Never again Shocked
Post #325653 23rd Apr 2014 6:42pm
Alex1976
Well I placed an order for a 1.4 box from Ashcrofts today due to turn up next Weds so that's my BH weekend project sorted out Whistle
I know some people have said they think it will rev too high at 70, but it is definitely too low revs with the current box. It was fine when I had it mated to a R380 but now its on an auto its needs the extra revs the 1.4 will give.
Once its in and I have driven it a bit I will let you know how it is.
Post #325883 24th Apr 2014 7:59pm
Alex1976
Well I have been driving the Defender around this week with the new 1.4 T box in and I am really pleased. It now seems to be just right. Better acceleration and still does not feel too revvy at 70. It will hold speed without an issue on hills now too.
I changed to a yellow speedo gear and thisnowgives me exactly the samespeedoreading as the sat nav rather than the blue gear that used to read a lot under.
Have to say I received first class service from Ashcrofts again. I can not rate Dave and his team highly enough. I mentioned that while I had the tbox out I was going to strip and clean the governor on the auto box and he threw the gaskets and seals I needed into the order for free.
Post #329430 8th May 2014 8:50pm
