![]() | Home > Puma (Tdci) > Odd noise |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 707 ![]() ![]() ![]() |
EGR cleaning itself? 2008 Defender 110 XS SW - M57N2 / 8HP70X
http://www.defender2.net/forum/topic12553.html?highlight=egr
http://www.defender2.net/forum/topic9641.html?highlight=egr http://www.defender2.net/forum/topic5841.html?highlight=egr http://www.defender2.net/forum/topic7356.html?highlight=egr If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
If it's not the 5x chuka-chuka from the EGR self-cleaning, it could be the death rattle of your clutch --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Dickie Member Since: 22 Jan 2014 Location: England Posts: 12 ![]() ![]() |
Sounds like the EGR Vv also doing it on the move mainly when backing off coming up to junctions.
Is it just a clean or a replacement job required? Cheers for the advice. |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2148 ![]() ![]() ![]() |
Hi Dickie
welcome to the forum its the normal self cleaning routine for the EGR valve and doesn't need any intervention from you at the moment. if it is excesive then you could try running a tank of higher quality fuel (BP ultra or simmilar) that made mine quieter for a time, or you could have a remap that will keep the EGR closed (as well as bost your driving power) ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
Hi
It can't be normal as this is a 57 plate with 52k on it and only just stared happening. Cheers |
It is a common occurence as detailed in previous posts and links. If you don't fancy living with it or trying any of the suggestions take it to your local independant and/or dealer and seek expert advice, initially all it will cost is a little time and a little diesel.
Probably ensued by a suggestion you need a new EGR valve. You could try cleaning it if you have the inclination. http://www.defender2.net/forum/topic2227.h...r+cleaning ![]() Treat every day as if it is your last....one day you will be right!! |
Hi Dickie as K9F says ... try the fuel first and then if your still worried take it to bits and see if it needs cleaning. Mine is an 07 plate with about 98k and it started scratching when cleaning after about 60k .. it never gave me any issues and I used hige quality fuel in about 1 tank in 6 that made a differance - however it's much better after a BAS remap that closed the EGR all the time (ie - silent!) There are many posts on the forum on this subject if you need more convincing - just search EGR and see what comes up! hope that helps ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
