Home > Technical > Puddle under fuel filter
Page 2 of 3 <123>
martinfiattech
Thank you young man that means I`ve got one free fuel filter in my toolbox to go on in few months time, a bit of welding Very Happy and a few quid saved. Very Happy Very Happy Excuse the spelling I`am better with spanners and wires.
Post #325180 21st Apr 2014 9:23pm
munch90
it does make the filter bottom closer to the axle rod trailing arm , so worth checking if you got clearance if loaded heavy or off roading
Post #325184 21st Apr 2014 9:35pm
martinfiattech
Ah thank you, now that's changed my plans a bit time to get the measuring tape out, we get a better discount at the ford dealer than lr would ever do. was hoping to source as many bits from them or psa / fiat for the engine as the wiring ect for our ducato is very similar.
As for off roading it`s been in the dealers for the last two weeks I get it back tomorrow Very Happy Very Happy
You seem to know your stuff are you in the trade I`ve seen your mot posts. Excuse the spelling I`am better with spanners and wires.
Post #325188 21st Apr 2014 9:53pm
munch90
yes trade ,but don't do so much now
Post #325191 21st Apr 2014 10:01pm
martinfiattech
Ah the lucky ones escaped the workshop, thanks for information. Excuse the spelling I`am better with spanners and wires.
Post #325193 21st Apr 2014 10:09pm
spudfan
Ireland
Before fitting the new filter lie directly the filter housing and look up at it when the old filter has been removed. This will let you see where the lugs in the new one line up, then once the new one is in place just twist until it locks in place. The Stanadyne filter has pictorial instructions printed on it. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #325503 22nd Apr 2014 10:35pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Luckily I ordered a Stanadyne one then Smile
Post #325522 22nd Apr 2014 11:46pm
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
If I recall correctly the original is designed to click into place and has an indicator for you to listen for the click. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #325554 23rd Apr 2014 9:48am
martinfiattech
That's why I`am putting a tranny one on they have a picture of a padlock on them to indicate its fully home as they can be a bit tight some times
It might be a tranny thing some are a bit hard to get at let alone know if it`s gone on all the way,
Already had one fall off on a ldv, not fitted by me I was on road test after it had been repaired.
Long walk back for a new one as I drove over it Embarassed Excuse the spelling I`am better with spanners and wires.
Post #325669 23rd Apr 2014 7:51pm
Natlas
Rolling with laughter Rolling with laughter Rolling with laughter Thumbs Up 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #325670 23rd Apr 2014 7:54pm
MichaelHead
England 2006 Defender 90 Td5 HT Tonga Green
Lou I use filter pliers for my td5 oil filter no probs at all
Post #325679 23rd Apr 2014 8:33pm
munch90
td5 has metal head and threaded on so pliers aren't really a problem to them , puma is plastic head and twist-loc
Post #325681 23rd Apr 2014 8:43pm
MichaelHead
Another Thumbs Up for td5 then
Post #325691 23rd Apr 2014 9:03pm
munch90
no reason why you can't use pliers on a puma , just don't tighten like a maniac , just a gentle twist till it stops
Post #325697 23rd Apr 2014 9:12pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
munch90 wrote:
transit ones are a bit longer and you can't fit the metal cover guard back on ,
but yes it's the same fitting
Almost, but not 100% correct.
The Transit 2000 - 2006, 5 Micron filter [Part number 4537951] is identical to the Defender filter and is a straight swap.
Its only the 2006 onwards, 2 Micron filter that is 30mm longer bodied and therefore won't allow the refitting of the cover
HTH Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #334149 28th May 2014 3:08pm
Page 2 of 3 <123>
