Home > My Defender > g-macks 110 300 tdi thread
Page 8 of 25 <123 ... 789 ... 232425>
g-mack
Aquarius0 wrote:
what are you still planning to equip on your landy?
Lots of plans for it! just as and when i have a bit of spare cash! this month i will be buying some sound deadening and a steering guard!! My 109 thread
my youtube channel
Post #325055 21st Apr 2014 1:03pm
Aquarius0
Poland
How many miles driven do you have on the clock at this time? And is the engine ok? Are these engines as good as people say?
Post #325061 21st Apr 2014 1:36pm
GUM97
^^My 300 Tdi is on 130-odd thousand, and it's been great (and still is!), no trouble at all! Thumbs Up An engine to TDi for!
Post #325077 21st Apr 2014 2:46pm
g-mack
mines nearly at 150k miles! it is now using water so either head gasket or worse cracked head! My 109 thread
my youtube channel
Post #325088 21st Apr 2014 3:37pm
VeeTee
Netherlands
Mine has now approx. 345k km on the clock, and no problems with the engine at all. I use it as my daily driver, next month a holiday trip to Italy (roundrip 3.5k km in a week), first a good service and distribution belt change. Thumbs Up Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #325093 21st Apr 2014 4:00pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
@ Gmack have you checked the P gasket ? It is a common point of coolant loss on the 300 Tdi and can fail catastrophically leading to engine failure.
The good side is it,s a cheap and relatively easy fix. 2005 Td5 90 XS
Steve
Post #325102 21st Apr 2014 4:29pm
g-mack
lou, first place i looked Thumbs Up im getting quite a bit of pluming white smoke once warm at idle so i presume thats the coolant leaking into Exhaust! although it is intermittent! My 109 thread
my youtube channel
Post #325287 22nd Apr 2014 1:29pm
Aquarius0
Poland
Any other typical problems with this engine? And which one is better? The 300 or the td5? Any tips on what to choose for some expeditions and offrad fun?
Sorry for the newby questions but just starting my adventure with Landys. Confused Don't drive faster then your guardian angel can fly...
Post #325580 23rd Apr 2014 11:55am
Tiger
Both are solid Engines
I've had a 300tdi and I currently have a TD5.
I like both Thumbs Up
Post #325581 23rd Apr 2014 12:14pm
g-mack
ive also had both. my opinion is: td5 is a much nicer engine to live with, quieter smoother more powerful easy to tune!
300tdi for me is much noisier less powerful but!!! easier to work on and an awful lot cheaper in repairs! and i think a lot less to go wrong!! tdi would be my choice for serious overlanding, but day to day td5!
only reason i went for tdi was i wanted something i could easily work on relatively cheaply!
for example, a turners cylinder head is 435+vat for a tdi. the td5 is 1000+vat!!!
i still miss my td5 though!! My 109 thread
my youtube channel
Post #325638 23rd Apr 2014 5:36pm
g-mack
removed front prop today just to give UJs a thorough check. all good so i greased em up and ticked it off the check list.
while i had the prop off i went for a quick drive as im getting a drone above 2000ish revs (guess-timate no rev counter) only does it under load! still doing it with front prop off but at least i can eliminate front prop UJs and diff from the search! My 109 thread
my youtube channel
Post #325804 24th Apr 2014 12:25pm
Aquarius0
Poland
Can anyone give me the exact dimensions for a self made roof rack for a 110? Can't find them anywhere Sad Don't drive faster then your guardian angel can fly...
Post #326529 27th Apr 2014 8:53pm
g-mack
Fitted engine watchdog tm2 this morning! (cheers Brendan top service)
feel happier now i can monitor the engine temps more accurately.
 My 109 thread
my youtube channel
Post #327225 30th Apr 2014 1:40pm
yostumpy
did you perchance buy this 110 from N. Kent, only I used to cycle past one regularly that was identical to the truck as you bought it, and its now gone. The chap was building a 101 in the garage. But it used to wear a galv. 'roo' bar on the front.
Post #328228 4th May 2014 9:48am
g-mack
Certainly did! Yea he was building a 101 looked awesome too very thorough job he is doing My 109 thread
my youtube channel
Post #328429 5th May 2014 12:50am
