![]() | Home > Maintenance & Modifications > Interior cleaning and use of Waxoyl or Dinitrol |
adamatdraycott Member Since: 11 Nov 2013 Location: Midlands Posts: 299 ![]() ![]() ![]() |
You can use Waxoyl and Dinitrol internally, but Waxoyl stinks, Dinitrol not so much.
The sticky finish of both will attract dust and anything else, so will need cleaning off with white spirit and re application. I have coated all internal fasteners with ACF50 which gets rave reviews on here... My truck being brand new I am very much preventing not curing... But it seems to go on quite well and creeps between panels and under bolt heads well |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677 ![]() ![]() |
another thing worth considering is dynamat, much easier to install while the cars being re built.
Only interior bits that need doing are the seams (don't forget the seams on the outside)along the floor/transmission tunnel, it will help keep any moisture or condensation from gathering (from any leaks).As fer cleaning use an APC (all purpose cleaner,Flash or Tesco own Daisy is good stuff) for a quick wipe down as its no or low foaming so leaves less residue,and a quick wipe down with panel wipes (Halfords) for a thorough de-grease I'd probably brush it on the interior to cut down on overspray.Also remove the door panels and spray the doors, being careful not to get it on the glass
FLFAMILY Member Since: 23 Mar 2014 Location: West Midlands, Sunny FL Posts: 45 ![]() ![]() ![]() |
Thanks all. Have the week off this week so will get it wrapped up this week.
