![]() | Home > In Car Electronics > Galaxy Tab 3 7" |
I found my Samsung wont charge from anything other Samsung charger when its dead flat , if its still got bit of life in it I can plug in to apple ipad usb charger (using Samsung lead ) and its ok but not if its dead
sorry not tried my blue sea usb on it |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5132 ![]() ![]() ![]() |
I use the mains charger off an inverter in the car seems to work fine. I never use anything other than genuine chargers for any tablet or phone, i just do not trust aftermarket products with sensitive devices
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6013 ![]() ![]() ![]() |
I was just using two generic leads that I use for my phone and the wifes phone, which work fine
I have also just tried the genuine Samsung USB lead that came with the Tablet and that does not work. The tablet is 87% charged. Either A) not enough current leaving the BlueSea / Cigerate socket USB convertor B) Tablet uses extra pins for charging that works fine with a 240v plug in charger but not with in car ones C) Other... 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Ragerover Member Since: 27 Dec 2013 Location: In a land far far away Posts: 145 ![]() ![]() |
Not the galaxies but with the ipad it runs different amps then an I phone
I've got a double plug in thingymabob and only 1 side does the pad |
DiscoStu Member Since: 30 Jun 2007 Location: London/The far north Posts: 255 ![]() ![]() ![]() |
It needs to be 2.1A plus to charge. I bought an adapter off of eBay that has a double output (says it's one for Apple, one for Android), it plugs into the standard Defender socket and works fine. My Disco 'best bits'
Defender 110 XS CSW 2013 |
mmm shame. I was rather hoping my BlueSea would do the job. Off to hunt the bay of e. 1999 Defender TD5 110
Just checked the specification of the BlueSea USB socket and the max output is 2.1A
Just tried it on a USB adapter like this http://www.ebay.co.uk/itm/NEW-3-WAY-CAR-US...20d4f189ef and with an output of 500ma, the tablet starts to charge. My thought, is the USB one above might have a different pinout (maybe an extra pin for charging) than the BlueSea one? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
My mate tried his Tab 3 8" on the same lead and sockets and that charged OK.
But in his car a USB charger he has charges mine but not his! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
