Home > Technical > Over reving when changeling gear
2dae
Australia 2008 Defender 110 Puma 2.4 SW Santorini Black
Seems I've got a wearied thing happening when I chage gears
Push in clutch , take foot of accelerator ,
Revs don't drop off for a few seconds a short delay in rev drop before gear change
More noticable in lower gears
I changed the sensor on the clutch system under the bonnet
Didn't make any difference
Post #324464 18th Apr 2014 10:24am
Waldo
If you sit stationary and rev up without having it in gear and then take your foot off the accelerator does the same thing happen? Defender 90 XS TD5 (03 Reg)
Post #324474 18th Apr 2014 10:57am
landy andy
Tdci's do that! Is that what you have?
Andy
Post #324512 18th Apr 2014 4:57pm
Cheshire110
Isn't this the 'check your brake light fuse' thing that confuses the **** out of everyone? Cheers, David
Post #324614 19th Apr 2014 12:06am
2dae
More checks over reving
I've checked a few things
1 it does rev normally when in neutral or in gear with clutch in
2 all fuses seem to be good but ill double check in the mornin
3 my Landy guys told me maybe the fuel sensor on the clutch ( it's near the clutch fluid filler ) so I changed it for a new one , fitted It rebled clutch , but still the same , seems to be more noticeable in 1st 2nd and 3 rd gear when you press in clutch and take your foot off accelerator it gild rev high for about 2-3 second before decelarating
Post #324624 19th Apr 2014 6:13am
2dae
Also. To mention
I've got a 2008 110 defender 2.4 motor
Post #324625 19th Apr 2014 6:19am
sounds like the anti-stall, mine does the same (2007 2.4)
Post #324629 19th Apr 2014 6:47am
2dae
Hey bp man
Where is the anti stall located
Have you replaced yours ???
What is the antistall used for i thought 1st gear only
Mine is noticable in 1st 2nd 3rd
Post #324656 19th Apr 2014 11:16am
Cheshire110
http://www.defender2.net/forum/topic28113....brake+fuse Thumbs Up Cheers, David
Post #324673 19th Apr 2014 1:17pm
willyj
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Forgive my stupidity but... I have the same reving problem but my brake lights work?? Does it still apply regarding the blown fuse?
Post #324692 19th Apr 2014 2:27pm
2dae wrote:
Hey bp man
anti-stall is part of the standard ecu map, i guess it really depends on how pronounced the revs are when you change gear. i can run up a hill in 1st or 2nd and the engine keeps the power on without any pressure on the accelerator, you can feel the engine "take control" - that's the anti-stall.
hth
Post #324806 20th Apr 2014 7:31am
Big George
United Kingdom 2008 Defender 110 Puma 2.4 CSW Blenheim Silver
Vehicle revs high when changing gear
My Defender been doing this sometime now, just seems worst lately, been advised to unplug 'over rev sensor' located under bonnet next to brake servo? Can't seem to locate. Can anyone advise please.
[/b]
Post #328834 6th May 2014 10:11pm
