![]() | Home > Puma (Tdci) > Clutch kit, which one to buy? |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 ![]() ![]() |
I only ever fit genuine clutches to customers pumas, the latest one has been modified to prevent the spring rattling noise I believe. Will be doing my own with a genuine unit in the next two weeks
loki Member Since: 12 Mar 2013 Location: Pula Posts: 16 ![]() ![]() ![]() |
Thank you for you answer .
How do you prevent spring rattling , how do you modify it? When you fit a new clutch do you replace also the slave cylinder , Ill never replaced it and I have now 150 000 km. |
The springs are already modified by the supplier think the centre of the friction plate casting is much stronger too. Yes I always replace the slave cylinder
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2480 ![]() ![]() ![]() |
since LR built so many versions of the clutch, which are still on the market, make sure you get the latest type (part number) Puma 110" SW
Which is the part number for the latest version of the clutch ?
Du yo have any suggestion where to buy the genuine clutch ? |
LR037956 or LR048731. NOt sure anymore which one is the latest. Check with any known (web) supplier. Puma 110" SW
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
My clutch was replaced last month by a maindealer and the invoice says clutch assembly LLR048731. 1982 88" 2.25 diesel
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 ![]() ![]() |
I recently replaced my clutch kit and bought all from OEM brands. The clutch kit was AP drive and the slave cylinder was Borg and Beck. I think when the new part number arrives it will be superceded anyway to the latest? Refer the microcat.Cheers.
Kind regards, Diluk |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
Just fitted an AP clutch kit in mine on Sat inc slave cylinder
What a difference in the drive ![]() Also fitted the same kit in a mates 110 less than a month ago. Over 3k later now, hes very happy also ![]() Both clutch plates in each vehical the springs were just about to pop out. Worse in mine & has done 30k less Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
Maybe I still have problems with my clutch because I didn't replaced the slave cylinder . When I'm changing gear it isn't going so smooth as it used to be . I'll try now with an genuine clutch and new slave cylinder , maybe this time I'll have more luck , Thank you all for your suggestions
