![]() | Home > For Sale & Wanted > [For Sale] Datatag 4x4 Kit |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
Just wanted to say thank you, my kit came today and will be fitted over the Easter break, great service. Cheers
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen Posts: 631 ![]() ![]() |
my pleasure
![]() Send a paypal payment direct using this link www.paypal.me/duckworthparts www.duckworthparts.co.uk My Direct Line: 01673 849873 Email: danroberts@duckworthlandrover.co.uk Supplier of Genuine Land Rover & Jaguar Parts For All Models Can also supply OEM & Aftermarket parts ![]() |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5139 ![]() ![]() ![]() |
Data Tag arrived by Royal Mail today, great service, thanks ever so much will most certainly deal with you again.
stu_007 Member Since: 23 Jan 2014 Location: Cardiff Posts: 99 ![]() ![]() |
Mine arrived today too; after I delayed delivery. Excellent service again thanks!! Current
2021 D110 HSE 2013 D90 XS Previous BP07 OZR D110 (1930 YBA) 2007 G4 Mongolian Recce Vehicle BP52GHZ D110 2003 & 2006 G4 Event Vehicle |
Fitted my Data Tag over the Easter Weekend very easy to fit all doors, bonnet marked. Transponders in upholstery and behind dash, data dots dabbed all over the car. Form filled in and posted.
defender_uk Member Since: 12 Aug 2011 Location: SW Scotland Posts: 197 ![]() ![]() |
any more likely????
pretty please!! 2020 First Ed 110. replaced by 2021 250 110 Commercial Defender_uk |
churchy Member Since: 28 Jul 2011 Location: UK Posts: 237 ![]() ![]() |
Feel a bit daft asking this question as I am sure I have read the instructions correctly!?
The etching fluid doesn't seem to dry or is it an absolute no go trying to etch onto painted surfaces? |
Daft question maybe but are you using the clear fluid in the little bottle and not the bottle with hundreds of black dots in?
I have had no trouble with the etching fluid, first clean the area with Meths to remove any wax or polish, then stick the transfer on, wait two minutes for the adhesive to cure, then using the little white cotton bud type applicator gently go over the transfer, do not leave for more than thirty seconds, then remove the transfer. You may find that some of the white plastic from the transfer has stuck to the etching fluid but a quick wipe with a rag and a little meths immediately removes it. After a short period the etching fluid drys and becomes invisible. I have used the etching fluid on both Land Rover two pack paint, water based coat and Acrylic Lacquer and cellulose and had no problems. |
Thanks for the reply - apologies but all good now I had wrongly assumed it actually etched into the paintwork instead of going uv if that makes sense!?
I know what you mean but it is supposed to be invisible except under UV that way the scroats cant find it and paint over it, unless of course they go all over the car with a UV light that is why you have th transponders and the data dots hopefully to much trouble to remove them all so they just walk away.
Received my registration certificate from DATA tag this morning all good.
