Home > Wheels & Tyres > Blackrock Wheels - Fit my Puma?
HMARR
Hi everyone,
Can anyone tell me if these will fit my 2010 110 Puma?
http://www.trademe.co.nz/motors/car-parts-...680256.htm
Cheers!
Hamish
Post #323792 15th Apr 2014 12:08am
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
No!! you need 5 on 6.5 in terms of stud pattern, and they are also probably too wide, and the backspace (offset) is prob wrong 2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #323793 15th Apr 2014 12:10am
HMARR
Righto - Thanks!
I'm clearly a bit of a wheel noob... cheers
Post #323794 15th Apr 2014 12:13am
K9F
12" wide!!!! Mine are 10" with 12 you could imagine the result dependant on offset.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #323803 15th Apr 2014 8:44am
HMARR
Hey K9F - are your 10" wide ones a good option? They look awesome, but have you needed to do any mods or do they just go straight on?
Post #324013 16th Apr 2014 12:45am
K9F
Bolt straight on. Mine are Mach 5s which are rarer than hen's teeth since production has now ceased but if you wish to achieve the look at a greatly reduced cost.....These are the same size and will bolt straight on.
http://www.paddockspares.com/5105165bkmo-15x10-black-modular.html
They are more than wide enough. Pictured next to my size 10...
Old picture but the truck in the background has the same size modulars fitted but with wider still tyres at 12.5".
Post #324041 16th Apr 2014 9:25am
HMARR
Hey thanks, I'll see if I can track some down in little old NZ! They look very cool.
Post #324203 17th Apr 2014 12:55am
