![]() | Home > In Car Electronics > Coax BNC earthing |
Morning Excossack,
If the outer sheath screens of your cables are correctly terminated to the BNC connectors and your connecting equipment is earthed correctly as soon as you mount them to the panel the panel itself will be grounded anyway. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6039 ![]() ![]() ![]() |
Evening K9F
The radios connecting are only earthed via the earth power lead. So, would adding an extra earth do any harm? Would it be worth looking at adding an earth from the rear section above the back door(which is where the panorama mounts are to earth? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Your radio is earthed, your aerial is earthed, their earths are connected together via 1) the coax's screen via the BNC connections and 2) the vehicle body.
Earthing's always good but surely everything that needs earthing is already earthed? The screen on coax is good enough by itself and you've got more than that already. I wouldn't go to the effort of adding yet more unless you've got a specific reason to. |
Agree! ![]() Treat every day as if it is your last....one day you will be right!! |
Thanks chaps. I will consider it done and I have enough earths! 1999 Defender TD5 110
