![]() | Home > Technical > Nanocom Evolution, Problems,Hints and Tips. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Good stuff either way! Mike |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2507 ![]() ![]() ![]() |
anybody?
![]() ............................................................. Earth first. Other planets later |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
I didn't have to install any drivers, just switched it on, got the codes from the website, entered them and it was away. Andy
Me to Mike |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Could be wrong, but the driver is for the Nanocom desktop program for the nanocom 1 series. The preferred connection is by RS232 through COM-1 etc, but most modern laptops/desktops only have usb connections, hence the need for a usb driver to be used in conjunction with a RS232 to usb lead.
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 589 ![]() ![]() ![]() |
Have been playing with my Nanocom today, Tried for ages to get the 'Nanocom Graphic viewer' to work but it wont recognise the files the unit saves
![]() So imported the data into excel and made my own charts, there are a few strange spikes but on the whole it all looks ok. Top chart is throttle positions and battery voltage Middle chart is injector readings Lower chart is road speed blue/airflow red/manifold pressure green Does anyone know if the Graphic Viewer is compatible with the Evolution? ![]() Click image to enlarge ![]() |
I too have tried to get the CSV files loaded into GV but found the files corrupted and were not recognized by the GV program so assumed that the GV is only compatible with nanocom 1 and not the evo. I use data capture and use excel to show the highest values and to make graphs to show the recorded values but find the graphs show too much data and the info I'm after is lost in the clutter. As CSV (comma separated values/variables) files are easy to read in excel it is easy to separate them and compare the info you are after, ie Fuel rail pressure, injectors, rpm, engine coolant temp (cylinder head) and then make a graph to compare the info you are after over the period you are monitoring.
Some light reading: http://creativyst.com/Doc/Articles/CSV/CSV01.htm |
Macpaul Member Since: 26 Mar 2013 Location: SW Surrey Posts: 439 ![]() ![]() ![]() |
Resurrection!
Can someone (and it might be you Lorryman!) explain to a non-IT literate bloke how to create graphs from the comma separated values files collected from a Nanocom Evo 2 on an SD card. I can open the .csv file in Excel, which produces what you might expect, comma separated lines of figures for each of the many parameters at a given moment in time, but I'm ![]() Thanks. Simon. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
Depending on the version of Excel used, a CSV file usualy opens with Excel automatically putting the values into separate cells depending on the commas
If you find that the data is all in one cell or column with comms still there, do this. Select the data The choose the data menu, then select "text to columns" then wehn asked for separator select "commas" Once you have the data in separate cells, just highlight and select "chart" |
Thank you. I'm trying this on Excel for Mac
![]() The data for each given sample (the whole line of output covering all readings at a moment in time) is in one cell, hence the confusion. I'll try what you suggest and have another go. And probably find myself a PC. Thanks again. Simon. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
no need for a PC, should work fine on a mac (i have a mac as well)
110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158 ![]() ![]() ![]() |
Got a problem with mine Evo 2 did the latest BBS V1.23 upgrade but my functions are locked the codes are entered correctly and saved have tried reinstalling the upgrade numerous times re entered the codes but still the functions are locked any ideas
willyj Member Since: 23 Oct 2009 Location: Carmarthenshire Posts: 204 ![]() ![]() ![]() |
Just purchased a nanocom evo second hand. How do I re-register it to myself(the forum etc.)?
also, I need to purchase defender td5 and tdci, do I need the can bus lead for the tdci? any help would be appreciated ![]() Cheers Wil |
Email them ask the question since the product will all ready be registered they can change it they are on holiday till monday 28th
