![]() | Home > Td5 > Interior trim |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Can you modify your existing trim panels ?
I have Td5 which I'm putting windows in and have been looking out for the window trims for some time on eBay - and they always sell for a real premium. |
you have a PM
Baklengs Member Since: 13 Apr 2014 Location: Bærum Posts: 11 ![]() ![]() ![]() |
Thanks for the PM, i don't have 3 posts yet so I'm not allowed to send PM myself! Will check and keep a sharp lookout on the page recommended.
As for modifying the existing panels, this will never be pretty because the roll that holds the rear seat belt is so big that you will have to cut away all the trim around it. On another note, I startet project "IPad mini flush mounted in the dash" today. Great fun! ![]() Click image to enlarge |
All fitted and ready for use! Came out quite nice
![]() ![]() Click image to enlarge ![]() Click image to enlarge |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
ooh i like the mini application. got any more pics how you did it? how is it connected? direct to amp? head unit?
![]() my youtube channel |
It's actually quite an easy design. Cut out iPad mini sized hole in the dash, take a 0,9 mm steel plate and cut it so that it's about 0,5 cm bigger than the hole in each direction, bend the top slightly so that you can attach it using the mounting screws in the top of the center console, glue the bottom, use car filler and fill in all around, sand down and repeat until happy, drill a hole for the USB charger cable and finally spray the hole thing with black plastidip! I've attached a strip of magnet tape on the back of my iPad so I pops right in and stays there, but I can also easily remove it from the dash. (Remember to take all measurements with the tape attached) I've mounted the head unit in the cubby and ran all the wires hidden under the carpet next to shifter, thru the fuse box and up. Had to extend all the original wires about 2 meters and also bought a 2 meter charger cable for the iPad. Total cost for project is about 40£.
Nice job
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5130 ![]() ![]() ![]() |
Don't know if this is any help but spotted this Puma trim for sale on Ebay which I think is what you are looking for perhaps you could make them an offer
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...769wt_1159 I have dealt with the company in the past and they were very helpful. I am sure if you arrange postage to your country they would oblige. |
-[Allan]- Member Since: 22 Mar 2014 Location: West Yorkshire Posts: 44 ![]() ![]() ![]() |
Nice job on the iPad and thanks for the write up.
