![]() | Home > Technical > Hydraulic PTO warning switch |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
What make of hydraulic pto?
Superwinch?? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17810 ![]() ![]() ![]() |
Looks very like a standard reversing light switch.
Andy80 Member Since: 31 May 2013 Location: Essex Posts: 492 ![]() ![]() ![]() |
Its a made by Webster drives.... Maybe standard'ish though not sure! Working towards Carry on camping!
The only thing is in the compressed position the switch is in open circuit , where a brake light would be compressed closed circuit.... Working towards Carry on camping!
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6188 ![]() ![]() ![]() |
Have a look on google here for Threaded ball spring plunger with switch
This type is available as N/O or N/C contacts Sort of thing that RS components would do I'd imagine. |
if you go to intermotor website , then catalogs ,then search by image bit think its at bottom of page , then select switches then reverse light switches then look to see if one looks the same ,,, when you click on number under image it gives you the thread size etc
sorry bit long winded post ,but may help |
Thanks guys, I will research alittle further and may even be cheeky a chat to my local car parts man
After a little further research I came to this on eBay
REVERSE LIGHT SWITCH - RENAULT MASTER I BUS 1980-1998 54300 (190710831341) ![]() Click image to enlarge [/list] Working towards Carry on camping! |
