Home > Technical > Bolt that connect alternator cable to battery
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Any know the size of the bolt in a Puma that is used to connect the alternator cable to the batter (and also the size of the ring connector on the cable)? is it M8 and 8mm?
Post #323279 12th Apr 2014 12:12pm
munch90
think your find the alternator cable goes to the starter then feeds battery back through main battery lead , the cable your saying about (the smaller one that bolts to battery terminal ) goes to fuse box under the drivers seat .
but the cable bolt is 10mm head , m8 thread size , 8mm hole in ring
Post #323284 12th Apr 2014 12:30pm
kmac
Thanks munch. Just that there's another threaded hole next to it to which I am planning to connect my headlight relay loom. Will get an M8 bolt and 8mm ring crimp/solder connector
Post #323286 12th Apr 2014 12:33pm
munch90
yes no problem ,that's what I done use the extra hole
Post #323287 12th Apr 2014 12:37pm
