Home > Puma (Tdci) > Trailer indicator flash
tobz102
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Don't kill me for 'not using the search function', I have done but can't find the full answer to my question
Last weekend I repaired my right rear indicator. The connector had been damaged and the previous owner had bodged it back together using bullet connectors, so it was full of water. I dried it all out and fitted a nice watertight connector - job done!
A week later today, I noticed I was getting the trailer indicator icon light up on the first flash of indicators - but with no trailer attached. I know some posts say this is completely normal, but I've had my truck for 6 months and it's never done it before, so what's causing it to start now? The handbook claims it should only flash when a trailer is attached.
If it is normal for them to flash, is it possible it wasn't working prior to me repairing the indicator and now it's working since it is fixed?
Toby
Post #323198 11th Apr 2014 11:39pm
Funny, I just posted similar including comments about the trailer light.....
Don't worry about it, it's normal for it to just flash the once.
If you are actually towing it will flash constantly when you indicate. Although it's something you don't really notice.
Not towing = single flash
Towing = flashing with indicator constant.
Not sure why exactly if you didn't notice it before? Are the trailer lights LED or incandescent?
Post #323203 11th Apr 2014 11:51pm
tobz102
Sorry I didn't make it clear - it was the rear indicator on the defender that I repaired. I haven't towed anything since ownership (6 months), I don't even own a trailer.
I'm quite an observant person so I'm 100% certain that before today it has never flashed before. Then today halfway through my journey down the M1 it started to flash on first indicate and it's been the same since!
I'm going to borrow a light board tomorrow and check to see if everything works, if so I guess it's nothing to worry about! Just very strange how it started out of the blue...
Post #323204 12th Apr 2014 12:16am
Alicat
Yep, quite normal mine does that. Flashes constantly with a trailer on.
Post #323212 12th Apr 2014 5:45am
landys1
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Santorini Black
Definately normal for trailer indicator to flash once without trailer lights plugged in....if it wasn't doing it before, you've probably fixed the fault Thumbs Up 1959 Series 2 Ragtop
1989 SWB Stationwagon
1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work)
2011 Puma 90 2.4 XS
Post #323215 12th Apr 2014 6:34am
driver9
I agree with the comments above.
Post #323226 12th Apr 2014 8:00am
munch90
yes that's normal
Post #323235 12th Apr 2014 8:39am
Are you running standard lights and relay or LED?
Post #323264 12th Apr 2014 10:33am
munch90
don't think the led relay flashes it once without trailer
Post #323271 12th Apr 2014 11:34am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
The RDX led relay does. You adjust it to do that? LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #323277 12th Apr 2014 11:57am
munch90
taken from site about the rdx relay
please read bottom bit
Have you noticed when you indicate the trailer light may flash once even when you are not pulling a trailer, well most other normal cars do not put a trailer light on for one flash. Well ours puts the trailer light when you are actually pulling a trailer. When you are driving without the trailer and you indicate the little trailer light will not flash.
Post #323281 12th Apr 2014 12:23pm
munch90
Post #323282 12th Apr 2014 12:24pm
WelshGas
Well that's Defenders for you? Mine does. 1 flash when indicating, without trailer attached. Trailer light flashing with indicators when trailer, which has normal bulbs, is attached.
I have the RDX light kit, except for the front wing side indicators. Whistle LANDYWATCH
Post #323332 12th Apr 2014 5:19pm
Same as the above posts's last sentence for me. Whistle
Post #323335 12th Apr 2014 5:36pm
tobz102
Tested with lightboard over the weekend and all worked a treat.
Just another Defender quirk I think
Post #323672 14th Apr 2014 4:23pm
