![]() | Home > Td5 > Coolant system pressure "vs" gagging at high rotat |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5977 ![]() ![]() |
The high temp reading and loss of power is not a rare Td5 problem. It is often cured by running a new earth to the ECM platform direct from the battery.
Andy |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
the temp gague flicks to the red and the goes to blue?
the coolant is boiling in the plastic reseviour? your water pump is not working. either the blades have rusted away or the pump bearing has failed and is not turning so the coolant is not moving as fast as it should be. The defender has migrated, leaving the owner behind. |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 714 ![]() ![]() ![]() |
I have had this problem & it was the head gasket /cracked head which is a common problem with Td5s
fmrodrigues Member Since: 27 Dec 2013 Location: Lisboa Posts: 6 ![]() ![]() |
Here goes a photo from the water pump.
Achuakh was right, the blades were completely rusted away. I just hope the overheating didn’t damage the head gasket! I will keep you informed. Frederico |
Here goes the photo.
Frederico |
Well, at least you still have 5 blades there.
I had two left. The defender has migrated, leaving the owner behind. |
Looking to the elbow, the antifreeze also wasn’t any good!
Frederico ![]() Click image to enlarge |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
Looks like they used caustic soada instead of antifreeze!
