Home > Maintenance & Modifications > Wireless winch remote recommendations
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I have a Warn xd9000i winch and would like a wireless remote.
Question is: are the low cost remotes as found on eBay (and also on goodwinch.com) ok or do I go for the Warn wireless remote.
http://www.ebay.co.uk/itm/Car-12V-Winch-Wi...2c70b15002
...or
http://www.arbil.co.uk/4x4/products/90287-...emote.html
Any feedback welcome.
Simon
Post #322926 10th Apr 2014 5:08pm
Lewisgregory8
2014 Defender 90 Puma 2.2 HT Fuji White
If i were you id go for the expensive one, a winch is something you don't really want malfunctioning
Post #322930 10th Apr 2014 5:17pm
I have the same type of winch on my Disco 2 and use the Warn wireless remote. I have had no problems with it during the ten or so years I've been using it.
I don't have a terribly high opinion of the winch, though. It's too fast for precision winching, the solenoids are prone to sulking, and the paint has almost completely flaked off. Disappointing.
Post #322932 10th Apr 2014 5:23pm
couplands
That's kind of my thinking too, but the order of magnitude in price difference just made me ask the question..Smile
Simon
Post #322936 10th Apr 2014 5:38pm
couplands
I use a snatch block with my winch if I want to slow it down. I also heard that wireless remotes introduce a slight delay when winching in or out, so that might be an additional cause of loss of precision..?
Re: the paint, mine was the same after 10 years. I dismantled it recently and completely repainted it with silver wheel paint, which is similar to the original Warn colour. So far it's looking as good as new...Smile
Simon
Post #322937 10th Apr 2014 5:42pm
JWL
I decided to give one of the cheap eBay ones a try especially at the price so went ahead and got one. Give it its due it has performed faultlessly the only issue I have is that when you press the button it is difficult to use as an inching, ie very small commands, however briefly you press the button it will always work for a second or two, a definate "on" then "off" sequence. In those situations it is better to use the plug in handset.
Post #322938 10th Apr 2014 5:51pm
I agree that it's easy enough to rig for a slower pull, but it's extra hassle (don't have the problem with the Huskys on the Defender and S1, now that is a good winch)!
Good idea re. the wheel paint, must give that a try next time I have the winch stripped.
To be fair to the Warn, it's as good as any other epicyclic geared winch and better than most. It'll never be as good as a worm and gear winch, but it is a fraction of the price. On reflection my assessment is a bit harsh - you get what you pay for.
Post #322939 10th Apr 2014 5:52pm
Mdm
I bought a warn one from d44 at a better price than the Arbil advert
3 yrs on no problems
Post #323351 12th Apr 2014 6:38pm
couplands
Yes, saw the D44 price, much better..Wink
Might just treat myself...
cheers
simon
Post #323352 12th Apr 2014 6:39pm
Mdm
It's plug and play plus a 12v supply. Good range and has taken a few dunkings without issue.
Battery in fob has lasted well too.
Post #323354 12th Apr 2014 6:42pm
Leenorthants
G
The ceap ones get worse and worse, until you end up standing next to the winch!
Post #323371 12th Apr 2014 8:49pm
landy andy
I've got the warn one. Was very good on my warn winch (winch died, not remote) till it died have now got working on a goodwinch. Great bit of kit. Good range, always works.
Andy
Post #323372 12th Apr 2014 8:51pm
couplands
Do the cheap ones operate in a way that if two of you have them, they don't interfere..?
I assume the Warn ones are ok to use together..?
Simon
Post #323373 12th Apr 2014 8:53pm
JWL
I must admit that with my el-cheapo remote I wired in an isolator switch so that it, or any rogue signals will not activate my winch. I should hate to be trundling down a road and some kid with his remote control car in his garden happens to be sending the signal for my winch to pull in, nicely bending my bumper in half!
Post #323378 12th Apr 2014 9:08pm
landy andy
Had my warn remote on mine for 6 years. Never got interference.
Andy
Post #323380 12th Apr 2014 9:15pm
