Home > Tdi > Defender wont start, need help |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5434 |
You can just hear starter spinning? Or engine turning?
Andy |
8th Apr 2014 9:42pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
when you say all you can here is the starter spinning, do you mean the engine isn't turning over? and its literally just the starter motor? or is the engine turning just not firing? My 109 thread
my youtube channel |
8th Apr 2014 9:43pm |
ha Andy you beat me to it! My 109 thread
8th Apr 2014 9:44pm |
jack21 Member Since: 08 Apr 2014 Location: newcastle Posts: 5 |
The engine is turning over, but it is not firing
8th Apr 2014 9:47pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2563 |
Turn the ignition on. Get under the bonnet and pull the wire off the stop solenoid (on the back of the injection pump under the pipes), then touch the wire to the terminal on the solenoid, you should hear it click as you touch it. If not that may be a reason for it failing, solenoid has failed so no fuel to the engine.
Another way to check would be to crack off an injector pipe and crank it and see if any diesel comes out. |
8th Apr 2014 9:52pm |
Are you getting power to the fuel solenoid?
Any immobiliser fitted? Working? Andy |
Theres no immobiliser fitted, i will check out the solenoid tomorrow.
How come i cant get any fuel out the bleed screw when i try to prime it though, thats not related to the solenoid is it? |
8th Apr 2014 10:00pm |
What make of lift pump did you fit?
Does the manual lever on the lift pump feel as if it is doing anything? I think the engine needs to be in the correct place whilst trying to use lever. (So that the pump is not being compressed by camshaft). So if you have fitted new pump, and it is on high point of camshaft you won't be able to manual prime pump. You can prime using engine with bleed screw removed. Try this and see if you get fuel. Any other issues before? Running ok? Andy |
8th Apr 2014 11:43pm |
The lift pump is bearmach, I think it must be on high point of camshaft, it felt like it was doing nothing.
Not had any running isues, well I did run out of fuel last week but I did about 60 miles since that so im not sure if that is related or not. |
9th Apr 2014 12:32am |
Doubt it would of helped and could well be related due to sucking rubish up the fuel intake.
As mentioned try bleeding, either with cam in different place, or with starter. Then if no fuel there start working your way back towards tank. Has new fuel filter got any diesel in it? Are you happy it's fitted correctly, so not allowing air to be sucked in? Andy |
9th Apr 2014 12:41am |
Was the new fuel filter before or after the running out of fuel?
9th Apr 2014 12:43am |
I changed the fuel filter after i ran out of fuel, did it the same time as i changed the lift pump, filled it up with diesel first aswell
9th Apr 2014 12:43pm |
