Home > Puma (Tdci) > 500 Amp Fuse in Pos Battery Cable
surf110
Brazil 2009 Defender 130 Puma 2.4 HCPU Fuji White
Is this fuse really necessary? My Td5 doesn't have one.
I think when I install the dual battery, I'll just get rid of it.
[img]https://www.defender2.net/gallery/albums/userpics/10175/normal_IMG_0103.jpg[/img]
Post #322296 8th Apr 2014 5:10am
munch90
I have seen the fuse blow when the starter goes wrong on the transit ,so I would refit the fuse
Post #322302 8th Apr 2014 6:48am
K9F
Is it April 1st? First and foremost by your avatar your current vehicle is NOT a TD5......
The fuse is there for a very good reason, design engineers with degrees have placed that fuse there having worked out various formulas and criteria for the electrical system of your vehicle. Why not stick your thumb on the negative terminal and your other on the positive to see what effect an unprotected battery has and how much amperage it will deliver? Once you're out of hospital and if you still have two thumbs you could drop us a line and let us all know, don't forget to fit your spurs beforehand it'll help with conductivity to ground!
Whistle Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #322313 8th Apr 2014 7:52am
landy andy
Yes you can just remove it as it's a new safety item that will probably never be required. I was going to bin mine but then found with a bit of alteration that I could leave it in place, and it actually works well for attaching other accessories to.
What batteries are you going to fit?
Andy
Post #322317 8th Apr 2014 8:12am
K9F
Shocked Let's hope.....Probably!!!
Doesn't your statement say anything to you?
On the 2.4 wiring diagrams I have access to it is depicted as a 400 amp fuse and is indeed for the starter motor.
It does serve a purpose obviously and your mpg will not improve drastically with the weight saved of removing it. If the 'T' arrangement of the megafuse makes it difficult for your dual battery fit source a heavy duty inline one but retain some form of protection.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #322318 8th Apr 2014 8:23am
landy andy
"Doesn't your statement say anything to you? ”
Yes. And I hope you enjoy driving your modern euro box with all it's air bags, crumple zones and ISO fixings, whilst wearing fire overalls, crash hat, and neck brace.
Post #322440 8th Apr 2014 6:39pm
K9F
Laughing
Forgot to mention the fire extinguisher and first aid kit. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #322502 8th Apr 2014 8:25pm
Removing a fuse for the sake of it? No no and no. Shocked
Post #322504 8th Apr 2014 8:28pm
K9F
Steve you sound like Jim Trott from Vicar of Dibley..... Rolling with laughter
Post #322509 8th Apr 2014 8:34pm
Rolling with laughter Whistle Rolling with laughter
Please bear in mind there is an expletive in there I think.
Post #322514 8th Apr 2014 8:45pm
Remove the fuse and fit a cut down M6 bolt, as they're much lighter than the fuse itself
These bolts are also handy for using in 13amp plug tops, makes them much lighter to handle, and definately safer because as they will never blow, you will never have the risk of jabbing your finger with a screwdriver when you try to change one!
Post #322599 9th Apr 2014 9:33am
