![]() | Home > In Car Electronics > What wire for spotlights |
4 x 55w will draw around 18 amps, so if you want them all on the same switch then your 32 amp wire will be plenty. If switched in two pairs then 2 x 16 amp cables will also be fine. Either way, 1 x 32 amp earth cable daisy chained to all four will reduce the number of individual cables needed to roof level. Darren
I ran the power for my light bar from the battery box, inside convoluted trunking next to the main +ve feed then up behind the heater and out behind the back of the bonnet.
I plan to buy another windscreen "hinge thingy" and weld/bolt a tube that will go up as far as the rack and run the convoluted trunking / wires inside. Polevolt.co.uk sell some good quality twin cable by the metre, together with quality relays etc. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6038 ![]() ![]() ![]() |
Cheers chaps for the info. I was wondering about the voltage drop hence going for higher amp wire. 1999 Defender TD5 110
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21015 ![]() ![]() |
The bigger the better.
![]() Most new vehicles always run thin wall generally, type in thin wall on eBay and you'll usually find some. I normally use this place: http://www.ebay.co.uk/itm/12v-24v-AUTOMOTI...3a8a9bd3b8 http://stores.ebay.co.uk/Choice-Cables |
Cheers. C90. I have been using http://stores.ebay.co.uk/kojaycatvehiclewiring/ 1999 Defender TD5 110
2 core might be the neatest solution for more visible areas, it's what I've used.
That sounds like a good idea to me! I was going to use split tubing and single strands of wire for each connection 1999 Defender TD5 110
