![]() | Home > Td5 > Last defender td5 to roll off the production line |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
It could well of been built in 2006, but registered until 2007
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
Does the logbook not say date built? I thought it did but could be wrong.
Also, slightly off topic, but I also saw a 56 plate Tdci...with no obvious custom plate hint... What a out the VIN? Will that not alllow someone to work out where it is in the sequence? 1998 110 300Tdi White Hard Top |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
Don't put your VIN on here or anywhere on the internet! www.td5.org
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17919 ![]() ![]() ![]() |
If you wanted to PM me your VIN I can see if my copy of Microcat contains the actual build date.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6700 ![]() ![]() ![]() |
V5C will give date of first registration, not build date. The build date is stored in Microcat.
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2673 ![]() ![]() ![]() |
Hijack...anyone know the last VIN of the last 2.4 (before the 2.2's)?
I know I was there or thereabouts... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Neil5489 Member Since: 19 Dec 2013 Location: Cheshire Posts: 87 ![]() ![]() |
Is it not possible to tell roughly how close to the end of production it was just by the vin
