![]() | Home > Maintenance & Modifications > Spring Compressor |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20870 ![]() ![]() |
Could Chris not help you?
The 'health and safety' gurus will be all over me for this one but as your need is relatively urgent and you're ready to fit by the sound of it:
If you can use your smaller compression tool to compress a section of your new springs some strategically placed heavy duty cable ties (or strops) can retain the compression. Move the tool and compress another section, progress until it is compressed sufficiently for your needs. Be careful and use sufficient ties. ![]() Treat every day as if it is your last....one day you will be right!! |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5942 ![]() ![]() |
If you have undone both dampers, removed both wheel, released both springs, and removed the ARB fixing. Then you should not need spring compressors.
But if you do for some strange reason then just use the ones you've got to compress as much of the spring as they can, and that should be enough. What is stopping the axle from dropping? Radius arms? What brackets are you fitting them with? Andy |
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
Thanks everyone, C90Steve, killer just a bit too far, K9F I have some ratchet straps so may try that, Landy Andy only had one wheel of, may be do both at once. Also your views on having both wheels off and dampers made me think the HD anti roll bar may be worth removing as I'm replacing it with the original. _______________________________
Puma Defender 90 |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
As Andy said .. Over the years I've fitted many springs, from Standard/HD/2" lifted etc etc to many Defenders ... Never needed a spring compressor.
With both wheels off and the shocks disconnected [And ARB if fitted] Whack axle stands under the chassis and drop axle as far as it goes ![]() Even on 2" lift springs, with a bit of extra 'Foot' pressure on the hub, you have ample space to ping the springs in .... ![]() |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 ![]() ![]() |
Spring compressor available for use if needed, and I'm not a million miles away.
Let me know. It wasn't me! |
Hi Ozzy57 I replied via PM but it kept telling me there was an issue! Thank you. _______________________________
Puma Defender 90 |
I had the same issue when I tried to PM you.
Anyway, got yours now. It wasn't me! |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
Yer mate, you wont need no compressors. Jack up and let the axle drop will be more than enough to get standard height springs in place
![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532 ![]() ![]() ![]() |
I put a +40mm set of springs on my 90 without compressors! Just jacked up the body with the shocks (rear) disconnected. Easy peasy.....
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1731 ![]() ![]() |
I used a small bottle jack to push the axle down further when i did it before. Defender puma dormobile camper
Thanks everyone, I'll be making another attempt this weekend. _______________________________
Puma Defender 90 |
Ken B Member Since: 17 Dec 2013 Location: Essex Posts: 106 ![]() |
Look forward to hearing how you get on as i need to replace some +2 springs and dampers (a little old and ready for refresh) so looking at what to buy and if i can do at home myself Defender 90 TD5 County -
You need only two tools in life: WD-40 and duct tape. If it doesnt move and it should: WD-40. If it moves and shouldnt: duct tape it. |
Well after putting into practice the advice given here, the new springs are in very simple just as stated by everyone. Even had time to change the rear ARB. _______________________________
Puma Defender 90 |
