![]() | Home > My Defender > My 2004 TD5 90 HT |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 419 ![]() ![]() ![]() |
Add a Defender2.net. Sticker to your list! Nice landy by the way
ChrisJ Member Since: 12 Nov 2013 Location: Warwickshire Posts: 231 ![]() ![]() ![]() |
Ah how could I forget
![]() Thanks! |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
My first mod would be to spin the tyres round on the rims so the writings on the inside, Other than that she,s a beaut
![]() Steve |
Macpaul Member Since: 26 Mar 2013 Location: SW Surrey Posts: 439 ![]() ![]() ![]() |
Hi Chris,
I'm cross-posting here but my suggestion first of all would be soundproofing. A raw hardtop is a tiring, noisy beast. I used a mixture of Dynamat and Noisekiller stuff. The Noisekiller eggcrate roof foam and wall linings were effective, and I lined the loadspace with ply laid on thin ebay foam. Dynamat best on the bulkhead and under the matting. Let us know how you get on. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
Soundproofing is on the list
![]() I think I may place an order in the near future for some Dynamat from Alive, I'll have a look into the noisekiller stuff, thanks for the pointer! |
I've owned the defender for just under two weeks now and have used it on and off for various journeys, overall I'm really pleased with it. I'm not really sure what I expected having only driven a Puma once a few years back but there's certainly scope for major improvements to suit my needs.
There are a few niggles ive picked up on whilst getting to know her, first of all reverse gear is difficult to change out of, fine going in but a stiff when going to select another gear, I'll change the gearbox oil and see if it helps. Secondly, I purchased the Defender as "serviced", clearly it hasn't been so I'm a little miffed, coolant level very low and oil level below minimum on the dipstick, my own fault for not checking when I picked it up, a service kit is on order from forum sponsor Advance Factor and should be with me tomorrow. Thirdly, with the heavy rain we had here last week there are two puddles in the footwells, all part of defender ownership I know, but needs sorting out before sound proofing. I've ordered a few bits, some Td5 badges for the wings, a new Defender badge for the rear, a service kit as mentioned above. I'm considering Dynamat at the moment from Alive, I'm not sure whether to do the whole truck in it or just the bulkhead and seat box and get some cheaper stuff for the rear and roof, opinions please? I'm also ordering a Toad alarm tomorrow so that should be here to for me to fit at the weekend ![]() |
I.AM_a driver Member Since: 11 Jun 2009 Location: Edinburgh, Scotland Posts: 404 ![]() ![]() ![]() |
Before you go changing the oil (a worthwhile exercise anyway if you've no idea how long its been in there) try pulling the gearlever towards you & it should pop into neutral no bother, if you are just pushing forward it won't go as easily.
NIce looking 90 you have got there. Mark S CONVOY for HEROES www.facebook.com/convoy4heroes www.lothian4x4response.org ------ Td5 90 Thread in 'My Defender' Forum |
A few jobs done on the defender over the weekend.
I purchased a service kit from forum sponsors Advance Factors, excellent service ![]() Whilst servicing I discovered the rocker cover gasket was leaking quite badly so a pm and a call to Dan at Duckworths and a new gasket was on its way along with an injector loom, all changed and I'm happy to report no more leaks! I changed the injector harness although looking at the original it all seemed ok so I'll hang on to that as a spare. Whilst ordering with Dan I got some new springs sent out as she was fitted with HD springs from the factory, I've ordered SW springs for hopefully a much smoother ride, I need to order some new dampers and a steering damper as mine have seen better days, I'm thinking of Bilstein B6, any thoughts? Another job has been to sound deaden the front and rear floor, being a hard top it's pretty loud inside, as she's being built to take away on some European trips and general holidaying around the UK it makes sense,I decided on ordering some Dynamat from Gary at Alive, a great price and I've been really surprised how far just two packs have gone! Pictures below I started by stripping out the seats, mats and giving it a damn good clean and then started dynamating the seat boxes and front floor ![]() ![]() Click image to enlarge I discovered I'm missing the battery box cover so ill do that once I source one, I haven't done inside the battery box or the under the drivers seat, is it needed? I figured not as the top will be covered but I'd be interested to hear others thoughts. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Next job in the front is to remove the dash in preparation for Dynamat on the bulkhead as well as installing my new alarm.
I moved on to the rear then, it was fitted with a plywood boards covering the floor, I was pretty surprised to find no less than 9 full dustpans full of c**p ranging from screwdrivers to a kitchen knife! Clearly had never been swept out in its life. ![]() I scrubbed it all out with some soapy water and let it dry off, looked much better after this. ![]() Click image to enlarge ![]() Click image to enlarge And then started laying the Dynamat, I've matted up to the rear side panels as I'm going to fit side windows in the near future so I didn't see any point in matting these. ![]() Click image to enlarge All matted and ready for carpet. I'll remove the rear wheel carrier from the bulkhead as seen in the above picture and also some brackets from behind the seats which held the jack and carpet over the bulkhead then re fit the jack brackets, that should tidy it up nicely. I have the carpet already as I ordered it from eBay. I order four sheets of this :- http://www.ebay.co.uk/itm/Car-Carpet-in-BL...3f32126734 I have way to much, I was originally going to order a front carpet set from Exmoor trim but may well give it a go myself with what I have. So jobs for this weekend are to fit the rear carpet, start removing the dash to fit the alarm, I've also got a central locking kit so I'll get round to that to whilst doing the alarm. I have a clutch spring kit to fit to make the clutch nice and easy and a few bulbs for the instrument cluster. I'm enjoying Defender ownership so far :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Last edited by ChrisJ on 1st Apr 2014 3:26pm. Edited 1 time in total |
Josh K Member Since: 01 Nov 2013 Location: Herefordshire Posts: 266 ![]() ![]() ![]() |
I can see your doing the job properly - cup of tea whilst working, top man!
![]() Looking for another to replace it. The road less travelled.... is a muddy one! |
Thanks for the advice! ![]() ![]() |
stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1034 ![]() ![]() ![]() |
If you would like, I can look for a battery box cover at Newbury this weekend for you
Thanks ![]() |
Nice job! There was certainly a lot of rubbish in the back! An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
