Home > Maintenance & Modifications > Differntial Filler Plug?
shaggydog
Hi Guys,
Does anybody know of a flanged differential plug that suits defender axles?
My front one has been tightened up so much by previous monkeys that its quite loose and I don't want to overtightened it and strip the threads, but as it is at the moment it leaks.
I know of discovery 2 filler plugs as here http://galleryplus.ebayimg.com/ws/web/2709...0x1000.jpg but not sure if they will fit early defender axles?
The Salisbury axle on the back has been damaged too and is being changed soon but would be nice to get them the same, any ideas?
Post #320577 31st Mar 2014 8:15pm
X eng? Alloy though... Confused
Post #320585 31st Mar 2014 8:24pm
shaggydog
Yeah have looked at theirs but they are the drain plug, I'm looking for filler which I suppose would logicically be the same? (famous last words)
Might get a standard filler plug and weld a washer on it see if that has the same effect though would be nice if I could get a purpose made one
Post #320614 31st Mar 2014 8:42pm
I would have thought they were the same, I considered them before but thought better of it in the end.
Post #320617 31st Mar 2014 8:45pm
shaggydog
Once my replacement diff pan has come I'll have a proper measure of it but I think this will work
http://www.marinemegastore.com/product-BRA..._19734.htm
Post #320622 31st Mar 2014 8:53pm
landy andy
They are the same part Thumbs Up
And you can use PTFE tape around it if required.
Andy
Post #320623 31st Mar 2014 8:53pm
shaggydog
Excellent news Thumbs Up
Unfortunately they already have a good few wraps of PTFE all round and still she leaks.
Its not like a flowing leak, just a wetness culminating in a drip which would be nice to get rid of Rolling Eyes
Post #320630 31st Mar 2014 9:01pm
munch90
the oringinal plug has a tapered thread , you may find a standard thread won't tighten properly or be very loose fit , also the surface round the plug hole is not made to have flange seal plug , or you may need to fit thick rubber washer on it to seal .
I normally just clean the tapered plug and wipe small bit of rtv ( silicone sealer ) on the thread then refit
Post #320633 31st Mar 2014 9:03pm
munch90
you can get a thicker yellow tape than the normal white stuff
Post #320635 31st Mar 2014 9:06pm
landy andy
Gas PTFE. Thumbs Up
Andy
Post #320641 31st Mar 2014 9:20pm
landy andy
You could use the flanged plug that you've listed and a sealing washer like these
http://www.autozone.com/autozone/accessori...51979_0_0_
Andy
Post #320644 31st Mar 2014 9:27pm
shaggydog
Trip to screwfix is required me thinks Thumbs Up
Will see what arrives in my package from Duckworths and may end up just getting some CNC'd up from stainless hex bar Thumbs Up
Post #320645 31st Mar 2014 9:28pm
http://4x4overlander.com/interior-products...andle.html
Andy
That link is to a Nakatanenga Leather Door Handle! Shocked Laughing
Post #320724 1st Apr 2014 8:30am
landy andy
Ohh. That's not what I planned. Embarassed Embarassed
Now changed to.
Andy
Post #320726 1st Apr 2014 8:31am
shaggydog
I thought you meant make a leather washer Embarassed
Link does look better will bear it in mind when I open my box from duckworths Thumbs Up
Post #320770 1st Apr 2014 1:05pm
