Home > Maintenance & Modifications > what oil ?
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
what oil ?
i know the oil shoulf be 5w-30 semi synthetic but what are people using as if got a 21000 mile service to do ?
cheers steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #32053 12th May 2010 1:12pm
MK
Once I uesed synth 5w40 Motul 8100 for the summer but my MPG dropped drastically. Back to the ford spec. Puma 110" SW
Post #32055 12th May 2010 2:12pm
spudfan
Ireland
On the receipt for my second service last week the oil used was listed as Castrol 0W/30. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #32061 12th May 2010 4:35pm
dgardel
Italy
Mobil1 ESP 5-W30 ACEA A5/B5 (superseded A1/B1) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #32085 12th May 2010 8:53pm
MK
A1 Fuel economy petrol
A2 Standard performance level (now obsolete)
A3 High performance and/or extended drain
A4 Reserved for future use in certain direct injection engines
A5 Combines A1 fuel economy with A3 performance
B1 Fuel economy diesel
B2 Standard performance level (now obsolete)
B3 High performance and/or extended drain
B4 For direct injection car diesel engines
B5 Combines B1 fuel economy with B3/B4 performance Puma 110" SW
Post #32086 12th May 2010 9:23pm
dgardel
Italy
this pics are better than 1000 words:
Nice to compare with lastest Ford WSS-M2C913-C
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #32151 13th May 2010 9:06pm
dgardel
Italy
see HERE  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #32154 13th May 2010 9:16pm
Naks
I'm also using Castrol Magnatec A1 5w30.
However, friend of mine is using Shell Helix HX7, and will switch to Shell Helix Diesel Ultra when it becomes available in South Africa in December.
He supplies the oil to the stealer when it's due for a service, and they use it, but there is no agreement on what this means for the warranty.
Post #46004 23rd Nov 2010 7:48am
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Castrol Magnatec A1 5w30. Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #46005 23rd Nov 2010 7:51am
Naks
I have found another oil which conforms to the Ford specs: Fuchs TITAN XTR 5W-30 (http://www.opieoils.co.uk/p-991-fuchs-tita...e-oil.aspx) and another Fuchs one: Fuchs TITAN Supersyn F 5w-30 (http://www.opieoils.co.uk/p-68918-fuchs-ti...-a5b5.aspx)
The Opie oil website gives all the oils that conform to the Ford spec WSS-M2C 913-B: http://www.opieoils.co.uk/c-698-wss-m2c-913-b.aspx#Filter=[Sort=1*ava=0]
And it looks like we should all be using WSS-M2C 913-C oils instead of the B spec, as per http://oilspecifications.org/ford.php:
Quote:
Ford M2C913-C
Fully backwards compatible and is strongly recommended for all applications that currently require the specification Ford M2C913-B. The new engine oil provides various benefits to the customer such as improved fuel economy benefits and high robustness to biodiesel fuels.
Post #46011 23rd Nov 2010 10:35am
BigMike
Karl is that an "approved" oil, warranty wise?
Post #46023 23rd Nov 2010 11:55am
Naks
That is the oil that most LR stealers use, and according to the marketing blurb, was co-developed by Ford & Castrol for the Duratorque engines.
Post #46025 23rd Nov 2010 12:02pm
DefenderOfTheEarth
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
So will Castrol Edge 0W30 work okay?
That's what I use in the 335d so would be handy if the same oil works for both! Defender 110XS SW gone... now VW California 180 4 Motion.
Post #46069 23rd Nov 2010 9:09pm
Bergos
Portugal 2007 Defender 110 Puma 2.4 HT Keswick Green
What exactly is "drastically"?
My economy dropped from 10l/100km to 12.75l/100km (28mpg to 23mpg).
Do you think that this could be caused by using 5W40 oil? Bergos
LR Defender 110 HT 2007 (2.4 Puma)
https://www.facebook.com/LR.Wanderlust/
Post #726739 2nd Sep 2018 10:25am
dgardel
Italy
for sure
also noted on my Defender Puma (5W50 vs 5W30 standard) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #726752 2nd Sep 2018 11:45am
