![]() | Home > Puma (Tdci) > acf 50 dye |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Apparently there is no dye in when it comes from the factory
I had a pipe leaking near the turbo a bit of chaffing going off ![]() |
there is no air con leak on mine just passed leak test , and I got glowing where there are no ac pipes ( like rear cross member ) , must be something else been sprayed at some time , but must by be me as no one else has ever touched it , and it is a rust proofing stuff because of where its sprayed ,
be handy to know what it is ! , makes it easy to see where you missed when spraying . nothing shows under sunlight or workshop lights only uv |
