![]() | Home > Maintenance & Modifications > Heater Air Intake |
chris bb Member Since: 14 Feb 2014 Location: South Hampshire Posts: 28 ![]() ![]() ![]() |
I've noticed that very little air enters the heater naturally and that I have to have the motor running most of the time for any effective ventilation.
Has anybody tried any of the "stick up" air intake modifications available or the (expensive!) KBX type? As well as forcing air in when moving perhaps they'll also keep some of the rain out when stationary? Series 2A 88, 1976 - 1980 Series 3 Lightweight, 1999 - 2011 200 TDi 90, 2012 - 2014 Puma 90, 2015 Wolf 90, 2017 - |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Have had one on for the past 4 years. Absolutely no problem. Just make sure the heating duct drains are kept clear on a regular basis.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Thanks, I know about two drains, are there more?
Did the "scoop" increase air flow? They're not pretty! Series 2A 88, 1976 - 1980 Series 3 Lightweight, 1999 - 2011 200 TDi 90, 2012 - 2014 Puma 90, 2015 Wolf 90, 2017 - |
None that I know of. Definitely airflow at speed without fan on, but I tend to run my fan on 1 or 2 constantly anyway.
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767 ![]() ![]() |
I ran the LRX (now KBX) type on my 90 for years and found it a massive improvement, air-flow even without the blower on was very significant.
Last year I removed (and sold) the LRX grills and fitted a snow-cowel. Apart from the issue that when there are strong side-winds the air-flow seems to be significantly reduced, the biggest issue as far as I am concerned is that natural through-flow is now non-existant (to be expected with the design of the intake). I am now in the situation that I will use the snow-cowel for winter only and purchase a new KBX grill for the remainder of the year. ONE LIFE, GET IT! |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
I have KBX and dont run my fan except when defrosting of for air con, definite air flow when moving without the fan on DEFENDER 90 TDCI XS,
