![]() | Home > Technical > Rear mudflaps |
Probably a rivnut spinning in the crossmember. Use say mole grips and apply a downward force to extract existing bolt. Then after reading the thread on homemade rivnut tool just tighten up the rivnut. HTH
Brendan |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6013 ![]() ![]() ![]() |
On my 110 the bracket mounted to the chassis had a bolt going right through the chassis from one side to the other. 1999 Defender TD5 110
landiedave Member Since: 14 Mar 2013 Location: Welsh Marches Posts: 60 ![]() ![]() ![]() |
ok thanks, I'll check out to see if the bolt goes right through, but sadly I don't think it does and I'll check out the homemade rivnut jobbie.
Cheers Guys |
Not sure if it's a standard fitment or not. 1999 Defender TD5 110
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
Given how most of the rivnuts seem to turn, even after the first fitment, this is how it should have been done in the first place. ![]() |
I replaced one of the rivnuts on mine with a regular nut and bolt. With a bit of fiddling, it's possible to feed a 10mm spanner into the chassis through the nearby circular hole to get to the back. I attached a cable tie to the spanner in case I dropped it inside. Darren
Maybe that's why I had no rivnuts on mine. Replaced with Stainless bolt/washers and nylock. And yes, that's how it should have been done! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
