![]() | Home > Maintenance & Modifications > Double cab rear tub protection. |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
I have been talking to a speedliner supplier in the area and it will cost £475 for the tub. What they do is take all the fixtures and fittings off, mask the bits you don't want doing and then re-assemble after. I like the idea of the spray on as there isn't that gap between chequer plate and the tub where loads of mud can squeeze in and corrode.
Glyn ![]() |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Has anyone seen a 130 tub ply lined thats what i will need and my joinery skill are not up to much
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 ![]() ![]() |
i am sure Mick you could do that if you can put shoes on horses should be no problem
