Home > Maintenance & Modifications > Checker Plate Dilemma...
Page 2 of 3 <123>
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
My 90XS is a worker, landfill sites, road works, quarries etc and without chequer plate on sills and wingtops would suffer from rigger boot scuffing, spanner scrapes,dents and all. Would rather not use it but without it the 90 would be scruffy. Black Mammouth 3mm plate on Santorini Black. It's like putting Waxoyl on the outside, a necessity for some of us. Use Rivnuts and gasket on wingtops.
Steve
Post #319994 29th Mar 2014 12:37pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
I wouldn't bother with the gasket, you never manage to seal all of it 100% and after washing you'll get water running out for underneath for days Mad
I wasn't going to put checker plate on the bonnet of mine as my last few have all had it and I wanted a change - plus the bonnet was nice and shiny! Laughing
that was until I went camping and nearly broke my ankle trying to load up the front of the roof rack from the wings. A bonnet plate was fitted as soon as I could and life is so much easier now
Post #320001 29th Mar 2014 12:50pm
K9F
I always use gasket it stops the crud from accumilating behind it. When I fitted the Entreq door strips I had to remove the sill chequerplate that didn't have any gasket. I was amazed at the 'dirt gasket' behind it and used a wallpaper scraper to remove the initial build up. I used butyl pondliner I had left over to make some gaskets before refitting. The bonnet I used the gaskets supplied and sealed up using black Sikaflex on the rest. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #320010 29th Mar 2014 1:54pm
Matthew_Mills
g-mack wrote:
im in the like camp! but has to be black! i think the wing tops look bare without it!
So does the black wear off, if it's anodised then I guess it will scratch and eventually wear away? If it's silver that matters less?
Post #320029 29th Mar 2014 5:18pm
Matthew_Mills
trooper wrote:
On met. dark blue black looks great on sills & wing tops.
Black and black... Any pics?
Post #320030 29th Mar 2014 5:19pm
Matthew_Mills
K9F wrote:
I always use gasket it stops the crud from accumilating behind it. When I fitted the Entreq door strips I had to remove the sill chequerplate that didn't have any gasket. I was amazed at the 'dirt gasket' behind it and used a wallpaper scraper to remove the initial build up. I used butyl pondliner I had left over to make some gaskets before reitting. The bonnet I used the gaskets supplied and sealed up using black Sikaflex on the rest.
When I did No 1 I used silicon rubber and wiped the edge with petrol... Worked a treat until the silicon began to degrade. I'm sure with care a decent seal to stop the mud et al that just rubs evening away as inevitably the metals will move against each other...
Post #320031 29th Mar 2014 5:21pm
Neil5489
Don't do it!!! Chequer plate is the devil!!!
Post #320218 30th Mar 2014 1:24pm
BigWheels
Why not go www.Turtleshell.co ? Idea Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #320383 30th Mar 2014 9:52pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
[URL=][/URL]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Euro-Leafing to infinity and beyond.....
Post #320481 31st Mar 2014 12:38pm
YeomanOfTheBar
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Santorini Black
Your wish...
 2013 Defender 110 XS DCPU
Post #320485 31st Mar 2014 12:48pm
Matthew_Mills
Brilliant thanks... where is that kit from?
Post #320491 31st Mar 2014 12:56pm
YeomanOfTheBar
The kit came from MM 4x4 in Droitwich (the wing tops are done too). I didn't order it directly myself, but had it added on when it was in for the lid over the load area. 2013 Defender 110 XS DCPU
Post #320500 31st Mar 2014 1:45pm
Grouse
@strang Shocked Rolling with laughter Rolling with laughter
Post #320533 31st Mar 2014 5:08pm
Think of the scratches in the paint if you don't:
Post #346057 18th Jul 2014 3:07pm
Dale
United Kingdom 2001 Defender 110 Td5 Tomb Raider LE Bonatti Grey
Guess I'm in the like camp. I must be a chequer plate bitch! Wink
Post #346120 18th Jul 2014 7:29pm
Page 2 of 3 <123>
