Home > Maintenance & Modifications > Winch Power Isolator
mse
I need to consider doing this...im not a fan of a big isolator switch - favouring something more low profile - any thoughts (without spending a fortune!) Mike
Post #31895 10th May 2010 6:18pm
TallPaul
big current needs big switch!
Could use big relay, and small switch? Marine relays go to a few hundred amps usually... Disco 3 gone but the memory of the bills remain...
XS 110 Utility maybe one day..... (did they fix the quality yet?)
Post #31908 10th May 2010 9:42pm
mse
Thats the sort of approach - both Warn and Land Rover have that option, better than those battery isolators - just after some options on type. Im aware of the current etc (although i also know its not as big as always thought) Mike
Post #31920 10th May 2010 11:42pm
TACK
The one from Goodwinch which i fitted was small and black so descret and unobtrusive too when fitted in the passender footwell, just recommendation Thumbs Up
Post #31923 11th May 2010 12:06am
leeds
Re: Winch Power Isolator
What sort of winching are you doing? Heavy duty competition winching or just occasional self recovery?
At full winch power a winch can demand 400-500 amps and that is why some of the serious comp boys use 50or 70mm2 cable
For self recovery at a pay and play site you are hardly likely to need that current. Double line and you half the winch power required and roughly halve the current required.
Next do you need to isolate the winch?
If your winch controls are inside your cab and solenoid pack high up in the engine bay then all you are doing are isolating a short section of cable from the battery to the solenoid pack. The solenoid pack acts as an 'isolator' to the winch.
If you have a winch wander lead socket externally mounted then you might consider a power isolator as a security feature against people being stupid with paper clips etc
So if you do want an isolator for your winch choices are
100 amp isolator. 100 amp continuous rated or 500 amps for 5 seconds (?) Fairly small. Cost around £7 mark
200 amp isolator. 200 amp continuous rated or 1000 amps for 5 seconds (?) Much bulkier unit. Cost around £21 mark
100 amp relay would cost about £25 plus cost of another switch mount etc say £5-10
200 amp relay would cost about £35 plus cost of another switch etc.
On our red 110 overland vehicle we have 2 winches and external mounted wander control lead sockets. Have a single 100 amp isolator to both winches as a 'security' feature
On Puma will probably go for internal controls and no isolator switch.
HTH
Brendan
Post #31934 11th May 2010 8:38am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Agree with Tack I've got the same small neat switch on the front of the battery box. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #31936 11th May 2010 9:06am
CFB
Me too, Goodwinch supplied, small and unobtrusive, black 'butterfly' shape switch, no key to lose Thumbs Up Andy
Post #31938 11th May 2010 9:37am
TallPaul
MSE, if it were me I would use the 200A relay from VWP:
http://www.vehicle-wiring-products.eu/VWP-...s.php#high
Same one was included in my IBS split charge setup, they are well made, and in the Disco I have 35m^2 cable and dual batteries never had any issues with too much current (so far). Disco 3 gone but the memory of the bills remain...
Post #31939 11th May 2010 9:42am
jst
Bear in mind the Goodwinch TDS current draw is not massive especially compared to some others so that Switch is ideal for them but maybe not for other makes Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #31941 11th May 2010 10:34am
TallPaul
Manual option of course is big anderson and just unplug the winch somewhere when not in use! Disco 3 gone but the memory of the bills remain...
Post #31942 11th May 2010 10:35am
leeds
Good option if you want demountable winches, however dependent where you locate the Anderson connector I would put an isolator switch in the circuit.
Have some photos of how some Baltic lads did demountable winches front and rear somewhere which I can dig out if people are interested
Brendan
Post #31944 11th May 2010 10:42am
Cibit
Thats mine fairly indiscrete middle of passenger side seat box
Got it here
http://www.devon4x4.com/products_a/p59c126...lator.html 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle
Post #31963 11th May 2010 2:41pm
Snap Thumbs Up
Post #31968 11th May 2010 3:49pm
mse
Thanks guys.
I probably should say im not new to this.
My current 9.5ti winch (personally the best winch for a defender...dont discuss Whistle ) obviously has the electrics in it.
I had the set up cibit has in the last 90 and im sorry its that im trying to avoid - as its not too bad granted without the key - but with, its not to my taste.
Manual isnt the way - so that rules out anderson connectors
Tallpaul - thanks i shall have a look at that.
I may reconsider the warn option Mike
Post #31972 11th May 2010 5:17pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
MSE was your warn fitted by LR? (agreed, 9.5ti is best on a fender ) aha. Ours came with an isolation switch, just small and discreet. 110 Tdci Double Cab
Post #31977 11th May 2010 6:01pm
