Home > Puma (Tdci) > Disable alarm when truck is accidentally lock with a door op
murrayb
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Java Black
Does anyone know if there is a way of disabling the alarm from sounding when you accidentally lock the truck with a door open? It's very easy to have the keys in your pocket and when moving kit about in the back of the truck for it to go off.... causing the horn to sound - normally for me at 2am or when setting off for a stalk Embarassed
Post #318941 25th Mar 2014 11:33am
JWL
I know on a Td5 if you have access to a Nanocom or the like you can disable the mislock warning sound, I'd be very surprised if it couldn't be the same on a Puma.
Post #318944 25th Mar 2014 12:02pm
adamatdraycott
United Kingdom 2014 Defender 90 Puma 2.2 SW Corris Grey
Disabling the alarm generally would be useful. As sometimes I may need to lock the dogs in the rear for short durations, and at the mo this is not possible as far as i am aware?
Post #319128 25th Mar 2014 10:44pm
JWL
As far as I was aware, if you locked the motor with one turn of the key in the drivers door then you set the perimeter alarm and immobiliser but not the volumetric part, the part that movement inside the vehicle sets off the alarm.
Post #319139 25th Mar 2014 10:54pm
adamatdraycott
I will try that at the weekend, cheers!
Post #319142 25th Mar 2014 10:58pm
JWL
Have a read here http://www.defender2.net/forum/topic7681.h...tric+alarm
There is also a tip about taping over the sensor and using the remote as normal.
Post #319152 25th Mar 2014 11:12pm
