![]() | Home > In Car Electronics > Amps, ISO and speakers |
| Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788
So at the moment I have a bit of a 'bodge job' with the speakers in my 110 and i want to sort it.
I currently have: - standard front speakers replaced with better 10cm ones, still using the same wiring- nothing changed there. - tweeters were installed from factory and i have them unplugged atm as they were all that could be heard at higher speeds - the rearmost speakers unplugged since i was struggling to balance them with... - a pair of decent 6x9s in separate enclosures in the rear which currently provide most of my sound! they are powered by a pretty good amp which takes power from the 'rear' red and white plugs on the back of the radio. what i want to know is: a) can i fit my 6x9s into an enclosure where the factory rear speakers are? I think i saw some on here a while back? b) without destroying the existing loom, can I send the amp outputs back into the iso block to out through the standard speaker wires? then I could have amped speakers using the standard wiring. I don't really want to start running new wires through the car as this introduced (i think) quite a bit of static last time. either that, or: would just replacing the rear standard speakers with 6x9s work? or for 6x9s do i really want them to be amped? would appreciate some help from the experts that i know many of you are! Cheers, guys Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
cheers Steve, ill reply to you via PM
