![]() | Home > For Sale & Wanted > [Wanted] Puma Central locking/electric window harness or par |
Hi Russ,
Take it you found your tester and the time to 'bell out' the cables? Offer of help is till there. I am sure with the kit I've got we may be able to run in some spare conductors and splice in with hermetically sealed splices without the need for gaitor cutting perhaps? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 ![]() ![]() ![]() |
Hey Mal, nah, I found a 12v led bulb and tested the connections with that. There's power at the connector in the door pillar but not the connection for the winder motor. I've no doubt with your expert assistance it would be possible to insert a new section of wiring without cutting the gaiter and splice it to the cables at each connector.
I'll be in touch very soon ![]() 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
