![]() | Home > Technical > Need to replace turbo where to purchase ? |
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
I,m sure some of the site sponsers can supply you with a new/recon unit, but failing that you could try Midland Turbo,s we use them at work and they will send a courier to pick up your unit check it out for you and phone before undertaking any repair work.They usually repair and despatch in a couple of days.
Check out their website for contact details. 2005 Td5 90 XS Steve |
| big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456
Bas site sponsor he does standard units and vnt for the td5 he will look after you and uses the company that rebuilds all of JLR turbos
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
| amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452
Thanks both for the info
Lou I might give them a call tomorrow to get an idea of price |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Aet turbos in Wakefield
| Skeggy 90 Member Since: 07 Oct 2013 Location: Skeg Vegas Posts: 233
The waste gate actuator will be set by the manufacturer you will not need to adjust it. I would recommend replacing the engine oil and filter at the same time. a number of turbo companies insist on this for warranty reasons.
| bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233
Hi
We have both VGT hybrid turbos and standard recon turbos in stock. Not adjustments are needed after fitting as all is done on the turbo flow bench when made. Please do remember you can't reliably check for baring wear by "lift" on the shaft when its not under oil pressure. The baring only works as a baring when its pressurised with oil that does remove and amount of shaft lift compared to when not pressurised. Std here. http://bellautoservices.co.uk/store/td5-de...bmenuid=57 Regards Pete. |
Thanks all again for input
Pete thanks for sharing your knowledge re play in the turbine bearing, every day is a school day With what you have said in mind is there anyway of testing my turbo to ensure that is it all ok? Any help is very much appreciated |
Hi
I cant give a real scientific answerwithout stripping it fully, however generally if the barings are really warn as you turn the compressor wheelbyhand to check lift is the comp wheel toughes the comp housing it has problems. Also the comp wheel blade tips should be sharp and not eaten away from debrit in the air or melted from overspeeding or hard work. Pete |
Ok thanks again
Will have a close look, If I find issues will be on the phone for recon unit Really appreciate your advice |
| cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642
Have you tried paddock they sell genuine garret ones
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
| theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
It is easy to mistake free play as failure. What is the fualt/symptoms?
To be honest there are no symptoms,
I have just been looking over the car to try to ensure that nothing lets me down on my trip to the pyrenees. I looked at the turbo as the car has covered over 200,000 miles. I found a bit of play in the spindle and assumed that it should not be there. Thanks to Pete I now realise that this does not mean I have a problem I'm going to have a closer loo at the weekend to see if the play is enough to cause any catching. It's probably me just being over cautious Thanks again to all who have offered advice |
Mine has a little free play and the finns are slightly worn aswell so will be replacing mine soon
