![]() | Home > Maintenance & Modifications > Fitting Roof Rack Spot Lights - Puma 110 |
DiscoStu Member Since: 30 Jun 2007 Location: London/The far north Posts: 255 ![]() ![]() ![]() |
Spotted the rectangular grommets yesterday evening - was looking for round ones lower down
![]() I don't really want to cable tie around the RAI - has anyone tried adhesive cable tie mounts, will they take the punishment? My Disco 'best bits' Defender 110 XS CSW 2013 |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
I like the idea of adhesive cable ties.......another idea for you...i have a friend who ran his cables on the inside of his snorkel. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
Ah, that's an idea
![]() Defender 110 XS CSW 2013 |
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 247 ![]() ![]() |
The G4's ran the cables through the snorkel, I just cabled tied on my 06, but not sure what I am going to do on the MY13, I don't have a snorkel yet.
I want to have the option to remove the rack (all though I may never do it). I could run a couple of high current feeds to the roof rack, and low curent switch connectors and mount the relay pack under the roof rack in an water resistant box, but it would be a PITA to trouble shoot. "Rafiki" 2007 110 STW - Rolling rebuild. |
Piratepaul Member Since: 28 Feb 2014 Location: Cumbira Posts: 8 ![]() ![]() ![]() |
THE BOY, where did you get your external visor from, look good
Yours is a very similar arrangement to my own. I decided to keep everything in one place and mounted the whole 'kit and kaboodle' in an IP rated enclosure. I also used DIN rail and Wago terminals to prevent soldering and heatshrinking cables but fitted bootlace crimps to go inside the Wago instead. I also dislike the standard automotive relays and sourced DPDT Releco 12v relays as they are so much more versatile with an internal LED to indicate when activated and a test facility to operate the relay without a triggering signal.
![]() Click image to enlarge
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Treat every day as if it is your last....one day you will be right!! |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605 ![]() ![]() ![]() |
So tidy
![]() Makes me feel bad.. ![]() Click image to enlarge |
Are you an electrician by chance? I am and mine looked worse than yours. ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Myo Member Since: 13 May 2012 Location: Cape Town Posts: 30 ![]() ![]() ![]() |
[quote="Myo"]So I want to install a light bar to my soft A frame. The wiring should be about the same, but I chickened out and got a KC Highlights loom
![]() Where would I run the cable to the light bar through the bulkhead? There's a rubber seal on the bulkhead left hand side, accessible from the panel below the passenger side dash, can I use this? How would I go about sealing this? I'm thinking maybe I should post some pics, as soon as I figure out how...[/quote] |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 ![]() ![]() ![]() |
Any idea what is the color of wire that goes to "+12V dash illumination" to tdci ? Can I connect it direct to +12V battery instead of dash? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
Don't connect it to "+12V Battery" - otherwise the switch will be permanently illuminated.
The dash illumination on a Tdci is - Red/Orange (Red with an Orange trace) This can be picked-up at an adjacent switch, or from circuit header C0286 (on a LHD vehicle) behind the centre dash facia. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Thank you very much Paul!
And what about this little blue/orange cable?? ![]() Click image to enlarge Says that I have to connect it with the same at the dash but I can't fint it… ![]() |
Blue/Orange is usually the RH main beam circuit.
Where does your pictured Blue/Orange cable come from ![]() What instructions are you following ![]() . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
It comes from 85 relay
I use fitting instruction No 53208 www.newfoundland.gr |
