Home > Puma (Tdci) > what is, what do?
Caterham
what is, what do?
Can anyone tell what this elec plug is for and if it is linked into the engine calibration etc?
Durrr. Edited to incl photo
Post #318410 23rd Mar 2014 6:25pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Tricky without a photo
Post #318411 23rd Mar 2014 6:26pm
Dieselhead
Oil pressure sensor??? Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #318485 23rd Mar 2014 8:56pm
Caterham
No idea
Just wondering if / how it links into the ecm / calibration
The wire seems like it's burnt / wire is brittle? if not a good connection could it affect engine running?
Post #318491 23rd Mar 2014 9:07pm
munch90
poss oil pressure switch
Post #318492 23rd Mar 2014 9:11pm
munch90
caterham are you still getting problems
Post #318506 23rd Mar 2014 9:42pm
Caterham
Would love to say no.....
Post #318509 23rd Mar 2014 9:50pm
bga86
2015 Defender 90 Puma 2.2 HT Fuji White
Oil pressure switch Thumbs Up
Post #318511 23rd Mar 2014 9:52pm
munch90
would you say noise is more like a clatter then a knock , like you would say you would get from a bit of petrol has gone in rather then diesel ( not saying you put petrol in ) , or sprayed bit of easy start in .
and does it do it after starting and running only few minutes ( cold ) and as you change gear
Post #318513 23rd Mar 2014 9:57pm
Caterham
Yes it does sound like a clatter a d i'm actually starting to wonder if it might be mechanical like the clutch?
There doesn't seem to be any consistency as to when it does / doesn't happen....
When it doesn't happen the engine / transmission is running really really well and as such makes it that much more frustrating (knowing how well it can run)....
Post #318519 23rd Mar 2014 10:02pm
munch90
right I asked someone about what I think your noise is
does it do it after sitting few days if so answer hp pump drying out , cure ? fuel running back ?
or timing error for split second , cure?
heard of one doing much the same , but sorry to say never found cause or cure as it only done it half a dozen times then never again !!!!!!
Post #318535 23rd Mar 2014 10:22pm
Caterham
No can't say leaving it a few days is likely to cause problem.
But yes to me it's like the timing has gone out of sync.........
Never found cure you say...... Big Cry
Post #318550 23rd Mar 2014 10:59pm
munch90
never found cause or cure , it stopped doing it !
think to be honest you maybe better off leaving it with someone to use it and poss found problem , I have had to do this in the past to find problem with customers cars if not doing it all the time ,
sometimes it's only way I used to take them home with me and drive normally hot , cold , short , long runs etc
Post #318556 23rd Mar 2014 11:10pm
Caterham
Biggest drive today since having new turbo and.......
I'm thinking the engine might be 'bang on '.......(might Razz )
....so what part of the transmission causes that characteristic clatter and what causes it to be more or less obvious?
Post #318781 24th Mar 2014 8:31pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
It's a Land Rover it is bound to make banging and clattering noises. Rolling with laughter Rolling with laughter Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #318785 24th Mar 2014 8:37pm
