![]() | Home > Tdi > Exhaust banging on gearbox |
| cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642
Anyone
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
| couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830
Sorry, not had this issue.
Did have a problem on my TD5 after I belted the centre box on a massive rock. Not only did it flatten the centre box, but the force was so great it bent the rear section and also the front down tube. My point is that you might want to check the other sections to see if they are damaged and affecting the clearances. Good luck Cheers Simon |
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
Does it have the standard defender engine or is is a discovery engine? In which case which pipe does it use from the turbo down pipe? (picture would be helpful) as I know some conversion kits are better than others and if its not angled properly or bodged in it can change the angle of the rest of the exhaust pipe and thus the rubbers which will lead to it banging or rubbing.
Also check the heat shield under the clutch slave as if this has rotated round or got bent could cause the same problem. |
Hi Simon Its been fitted with a brand new defender 200tdi exhaust full system with a bracket that it welded to the exhaust and then bolted to the engine hence why its so rigid 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
Its a defender 200tdi with a full new exhaust system fitted with a bracket that is welded to the down pipe then bolts to the engine, hope this helps and I will check the slave cylinder heat shield is not damaged or loose 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
The down pipe I ment about the bracket sorry 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
on my old 200tdi I fitted a flexi joint in exhaust ( cut pipe then slotted flexi in they tac welded so it was in right place then removed to weld round )
you can buy just the flexi joint from most motor factors, good make are bosal ones measure pipe as they do lots of sizes made a diffrence to vibration through body |
Getting the engine / gearbox mount rubbers to sort this issue on Monday with a load of other stuff aswell and hopefully going to do everything next weekend
Finally getting round to replacing the engine mounting rubbers tomorrow gearbox mount rubbers will be done next month
Here is a pic of one of the new series 2/3 engine mount rubbers that I fitted just before I replaced the timing plate
Graham
